umm maybe a dumb question, but i gotta
Discussion in 'Photography Beginners' Forum' started by arcticreaver, Mar 7, 2010.
  1. arcticreaver
    arcticreaver TPF Noob!
    Mar 7, 2010
    i have the rebel t1i with the original lens that came with it. i believe it's a 18-55mm lens. i see that the lowest f/number i get is 5.6. are f/numbers dictated by the type of lens you got?
  2. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    Nah, that indicates the type of battery
  3. KmH
    Apr 9, 2009
    40,742
    5,588
    Iowa
    First off it looks like you 'shift key' isn't working.
    5.6 isn't the lowest f/number you have.
    Here's what the numbers on your lens mean:
    At 18 mm the maximum aperture of your lens is f/3.5 (which is actually a big number because it's a fraction). The opening in your lens would be 1/3.5 as wide as 18 mm or 5.14mm wide.
    At 55 mm the maximum aperture of your lens would be 1/5.6th of 55 mm or 9.82 mm wide.
    Both numbers only describe the maximum aperture your lens can achieve at the extremes of the zoom range 18mm and 55 mm. you can adjust the aperture to much smaller numbers on the order of f/16, f/22, f/32, etc. (I'm not familiar with the lower limit of that lens)
    Your lens has what is known as a variable aperture zoom. If you set the aperture to f/3.8 when the lens is at the 18mm focal length and then zoom the lens to 55mm it will automatically change the aperture as you zoom until it is at f/5.6 when you reach 55 mm.
    Constant aperture lenses cost more, because they are more difficult to manufacture. A constant aperture lens has just one number after the zoom range, like 80-200 f/2.8.
  4. anm90
    anm90 TPF Noob!
    Dec 21, 2009
    148
    San Luis Obispo, CA
    The lens that it comes with is this lens here: EF-S 18-55mm f/3.5-5.6 IS
    It has a maximum aperture of f/3.5 at 18mm focal length and 5.6 at 55mm focal length. This means that as you zoom out, the aperture varies.
    Since the aperture mechanism is inside of the lens, the lens is what dictates the aperture values that it can obtain.
    Some lenses have a maximum aperture that is constant, such as f/2.8 (many high quality zoom lenses are constant f/2.8) or f/1.8 (like the 50mm prime that Nikon/Canon have)
  5. arcticreaver
    Mar 7, 2010
    thanks for the help guys.
