Understanding Histograms
Discussion in 'Beyond the Basics' started by JmPhotos, Oct 8, 2007.
  1. JmPhotos
    JmPhotos TPF Noob!
    Oct 7, 2007
    42
    What should a properly exposed photos histogram look like?
    Jodie
  2. Mike_E
    Jan 26, 2007
    5,327
    266
  3. harkain
    harkain TPF Noob!
    Jan 26, 2007
    34
    The short answer is this: it depends.
    The left end is shadows/dark and the right end is highlights/light. If it trails off either end, then you are clipping some shadows or highlights, depending. But that isn't always a bad thing. Generally, if all the data is at the left, the picture will be dark and if at the other end, then it will be lighter. But again, it depends what you are photographing. If any part of the picture contains some dark hole or deep shadow, even a tiny one, then you will see clipping in the shadow end or if there is glare you will probably see some apparent clipping in the highlights.
    I believe as a general rule, you want your histogram data to be more to the right, but not clipping. But, again, it depends on the subject matter.
  4. JmPhotos
    JmPhotos TPF Noob!
    Oct 7, 2007
    42
    Great website! Thanks. Now I'm beginning to understand. I will be checking out the histogram more often now.
    Jodie
  5. pandinus
    pandinus TPF Noob!
    May 21, 2007
    108
    Stavanger, Norway (moving to Bergen in November)
  6. hammerhead_05
    hammerhead_05 TPF Noob!
    Jul 27, 2007
    35
    West Michigan
    yeah......just as HARKAIN said.....it depends on the subject. Never think of a histogram as a 'right' or 'wrong'....but you must read it and interprut it based on what you are shooting and what you want to show. For example - if you are shooting a portrait of someone, generally you dont want anything overexposed - and the histogram will show that before, during, and after you expose the picture. This alows you to see what you have done before you leave your client and notice it after it is too late.
    Again - think of a histogram as a piece of information about your pic. It helps you see whats really going on with your pixels. Hopefully i didn't throw you for a loop.:confused: lol
    |Brock|
