Underwater Photography
Discussion in 'Photography Beginners' Forum' started by Joseph Elliott, Feb 20, 2007.
  1. Joseph Elliott
    Joseph Elliott TPF Noob!
    Jan 11, 2007
    15
    Bonnyville, Alberta, Canada
    I am writing a book and will need underwater photos for it. Anyone know what kind of equipment i will need? Can I use my current camera of will I need a different one? I'm currently using a Fujifilm S5100. Are there special techniques I'll need to learn? It will be mostly subsurface shots, and I can't see myself going down more than 10 - 15 feet. oh and it will be in fresh water.
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    You may be able to find a water proof case for you specific camera.
    What will you be shooting underwater? Will this be in lakes? In Alberta?
    The thing with water, is that it can eat up light...especially when there is a lot of sediment (like Alberta lakes).
    What quality of shots are you looking at getting? Pros who shoot fish (usually in the ocean) will usually have some sort of off camera flash, maybe a pair...because any light coming from the same direction of the camera...will cause all the debris in the water, to show up as specs.
    I can't help any more than that...I've only ever shot underwater with those cheap, disposable underwater cameras.
    I found this link, looks like it might help... http://www.jaytreat.com/Diving/Photography/Basics.htm
  3. Joseph Elliott
    Jan 11, 2007
    15
    Thanks for the link Mike, i will be shooting in lakes back home in Saskatchewan, everything from crystal clear to silty waters.
  4. Jake42
    Jake42 TPF Noob!
    Feb 12, 2007
    27
    VA
    Im pretty sure its hard to find underwater casings for FujiFilm cameras. But if u do, good luck. if i find one i will post it up here.
  5. ericande
    ericande TPF Noob!
    Oct 23, 2006
    136
    Seattle
    I took my pentax point and shoot with a case Scuba Diving in Hawaii. All I can tell you is without a seperate flash you are screwed unless the water is very clear and bright.
  6. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    i agree a hard case maybe hard to find, but they do make soft/bag case
    [​IMG]
  7. Joseph Elliott
    Jan 11, 2007
    15
    From what I have found they don't make a hard case for my camera but that soft case should work ok. The flash on my camera is on-board and there is no place to attach an extra one, time to upgrade?
  8. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    Time to try the Nikonos cameras.
  9. Joseph Elliott
    Jan 11, 2007
    15
    where should i start looking to find one? have they made any since 1992?
  10. Jeff Canes
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    B&H still sales them new and Nikon has it list on their site, also look in to Sea & Sea they have several digital models
  11. neea
    neea TPF Noob!
    Nov 27, 2006
    710
    Canada
    Bonnyville!!!!!!!!!!!!!!!!!
    Welcome neighbour!!!!!!!!!!!!!
    Greetings from Vermilion.
    EDIT: You related to any Elliotts here?
  12. Groupcaptainbonzo
    Groupcaptainbonzo TPF Noob!
    Nov 9, 2006
    463
    Turners Hill, West Sussex, UK.
    If you look at PRO SPEC underwater cameras. You will see they all have VERY wide lenses and off camera flash. This is because if you use "Standard" flash and lens set ups you will see all the bits in the water. and little or nothing of the subject which is about 15 to 30 feet away....
    You need to get VERY close and use wide angle shots with the flash Well off to one side..
