Unfinished Church HDR
Discussion in 'HDR Discussions' started by Einstein, Aug 7, 2010.
  1. Einstein
    Einstein TPF Noob!
    Jan 3, 2010
    228
    Bermuda
    These are my first attempts at HDR using photomati. C&C appreciated, thanks!
    [​IMG]
    [​IMG]
    [​IMG]
    4
    [​IMG]
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    i would suggest running them through ps and tweak a bit with curves to boost the contrast; not much just a bit as on my monitor they are a tad flat.
  3. Bynx
    Bynx No longer a newbie, moving up!
    Feb 8, 2008
    2,804
    366
    Just outside Toronto Canada
    I agree with ann, just a wee bit. #1 seems a bit soft too. But I really like what you have done here.
  4. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    wow... they are almost glowing from the radiation...
  5. Wheels47130
    Wheels47130 TPF Noob!
    Apr 22, 2010
    77
    Dayton Beach FL
    I like 2 & 4 the best. Good start. We only get better with time.
  6. Einstein
    Einstein TPF Noob!
    Jan 3, 2010
    228
    Bermuda
    Ann / Bynx: I will try boosting the contrast. When you make these adjustments do you do this to the merged JPG image after you have merged it or do you edit each raw image before you merge with HDR software?
    Nate: Is there a radiation reduction button in photmatix?
    Im just playing with all the different things the software can do at the moment, aggresive and natural. Are there any good tutorials that break the software down?
  7. NateWagner
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    well, really 1 and 4 aren't as bad in my subjective opinion. 2 and 3 are the killers just because they look so unrealistic, and also cause of the halo's around the changes in color.
  8. Bynx
    Feb 8, 2008
    2,804
    366
    Do your tweeking in Photoshop after you have merged them.
    [​IMG]
  9. ann
    May 14, 2007
    4,263
    189
    I start with RAW files in PS to see if anything needs to be done i.e. CA work, then apply any changes to all images at the same time.*(I use anywhere from 5 to 9 images).
    Then merge in PHotomatrix as a tiff file and after working with the image there i move to PS for additional changes.
  10. Einstein
    Einstein TPF Noob!
    Jan 3, 2010
    228
    Bermuda
    Bynx i agree the contrast helps.
    Ann thanks i will try doing this as well. Does saving as a tiff as apposed to a JPG have any advantages? I need to do some reading on the different file types. So far I just go from RAW to JPG.
    Also does shooting more exposures help make the images look more real or reduce the halos and radiation look that nate pointed out?
    Tonight im going hunting for some good youtube videos on HDR!
  11. ann
    May 14, 2007
    4,263
    189
    more information is available with tiff files as they aren't compressed like a jpeg.
    it is my experience with the type of work i am doing with HDR that more exposures give a great sense of dimension.
  12. AverageJoe
    AverageJoe TPF Noob!
    Sep 16, 2007
    918
    4
    Minneapolis, MN
    Like Ann said, use the Tiffs, they can handle 16 (and even 32) bit images. Also, have you tried using the other function of Photomatix? Try the Tone Compressor feature if you haven't already.
    PS: the brick is my fav.
church hdr tutorial
