Untitled #13
Discussion in 'HDR Discussions' started by Battou, Jul 20, 2009.
  1. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    Taken with Canon FD 50mm 1.4 on Canon EF, ASA 400
    [​IMG]
    Bigger Here
    Five exposure processing
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. Restomage
    Restomage No longer a newbie, moving up!
    Jul 3, 2009
    517
    25
    Fort Collins, CO
    I think it's still a little too dark, try using only the first four and see how it comes out.
  3. Battou
    May 10, 2007
    7,997
    26
    I reduced the brightness three points intentionally in Photomatix, I wanted it that way.
  4. HeY iTs ScOTtY
    HeY iTs ScOTtY TPF Noob!
    Jun 29, 2009
    380
    north west indiana
    is this suppose to be a hdr?
  5. Battou
    May 10, 2007
    7,997
    26
    No, it's actually an EDR, never the less the processing is the same and I perfer not to over process to the cartoony haloed look commonly associated with HDR. That cartoony look is not a required element of HDR. I thought this looked like utter horseshit, so I compressed it, perhaps a little too much but still. I use the tone compression differently than most people. The one fact remains, the dynamic range of the photo is higher than my film scaners censor can pick up in a single pass. Normally I don't go and make any special connotation of this processing drawing attention to it as a special processing as the film used can easily cover the range of the scene. Therein lies the biggest problem I have with your question...You expect HDR to look like the other photos in this section of the forum where the dynamic range is blown way out of proportion and exceeding that found in reality. Truth is, HDR is a processing tequnique that when properly done should only be noticable only by people who know limits of photographing technology. Scenes where the dynamic range exceeds that the cameras censor can capture, it's ment to encumpas the whole range of a scene, not surpass it. Scenes like a dark room with a window where the window would be blown out and the room underexposed and things like that. I use HDR processing to push beyond the limits of my tools and photoshop ability, not reality. This is my preference, and I can assure you I am not alone in this.
    Thank you, This early morning photo may not be the most visually appealing but it has more dynamic range than one shot is capable, processed in a manor that is barely beyond notice, leaving the shadows intact, Reduced in intensity but intact. My entire reason for posting this in this section was specifically for that responce right there as a bit of a political statement. The end photo is strongly influenced by the shooting photographers prefferences, that said, it's innappropriate for one to slam a persons image because it does not match their own concepts of what HDR should be. HDR processing is a very broad tool making a lot of things possible, almost as many as Photoshop. It's important to keep an open mind when viewing HDR imagery.
    If anyone would like I would be happy to provide 800x527 copies of the original five scans for more direct comparison.
  6. SrBiscuit
    SrBiscuit TPF Noob!
    Apr 22, 2008
    2,721
    44
    NH
    looks like a nice spot to shoot!
    challenging though i imagine.
    i see some halo'ing over the trees, and i agree that it does seema bit dark (but if that was your intention, you have achieved it)
    just out of curiosity, why did you want it so dark?
  7. John Godwin
    John Godwin TPF Noob!
    Jul 28, 2009
    38
    Kind of seems the same as the fourth picture, to be honest. I'd have just used the third picture and used a mask to darken other areas, I can't see the benefit of the extra effort of 5 exposures, really..
    I like to think I have a pretty good knowledge of camera technology and it's limitations, but I absolutely cannot see the extra detail in this image, it looks like it's pretty much straight out of the camera. There doesn't seem to be any detail in the shadows or the highlights.
    I think you went a little bit too understated.
  8. Wyjid
    Wyjid TPF Noob!
    Mar 28, 2008
    836
    Muskoka Canada
    i like the look of the properly exposed image best. i'd almost not bother trying anything fancy with this one. selective dodge burn can accomplish the same sort of result but much more flexibly.
  9. Mendoza
    Mendoza TPF Noob!
    Apr 24, 2009
    159
    California
    Would you post the original scans please?
    Re: HDR~
    Once a person gets the concept, High Dynamic Range is easy to use. Far more difficult is knowing if, when, and exactly how to use it. First one needs to decide whether or not the technique is even suitable for the desired shot, which requires practice and some ability to pre-visualize. After that, one must determine and select the proper range of exposures. Then one can begin processing the image.
    Since HDR is becoming more popular and recognizable, it does tend in its extreme implementation to look like a very specific effect. The effect is cool, but the software has potentially over a dozen parameters for processing the image so fortunately not every single picture has to scream "HDR"; it can be used subtly within the software or processed and blended/mixed with one of the exposures to tone things down.
    Fundamentally, it's simply another tool or technique available in photography. Quite an advanced tool to be sure--rendering it prone to misuse or overuse, but a valuable one nonetheless.
  10. Battou
    May 10, 2007
    7,997
    26
    Actually that halo is not a processing halo...it's visable in the latter two original scans as well. Halo none the less but it was there before hand, I dunno what's up with it.
    This was shot at about quarter after seven in the morning, I wanted to capture the hard early morning light cutting throught the forest wile maintaining the the dark wooded feel
    Maintaining straight out of the camera feel is a big objective as well as what I mentioned earlier. The film I was shooting at the time was fully capable of capturing the the hard early morning light cutting throught the forest with the the dark wooded feel intact, however my film scanner is not capable of getting everything the film can, Like I said earlier "I use HDR processing to push beyond the limits of my tools and photoshop ability, not reality."
    For me, the benefit of the extra effort is crystal clear, but generally I perfer the viewer be clueless to it. I'm sure if you where using the same scanning equipment I am on the same time constraint I am, you would see it too but....
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  11. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    Hey Battou!
    I honestly think you could have gotten (and looks like almost did get) VERY close to the your final shot without any HDR/EDR. I would play with it myself but its too late to be installing photomatix right now. :lol:
  12. Sachphotography
    Sachphotography TPF Noob!
    Jun 17, 2009
    1,229
    Tulsa, OK
    That scene would have benefited from a graduated neutral density filter very nicely. Forget trying to do an hr of the scene. That is not a good choice. Rather, get a graded neutral density filter and extend the exposure a little. You will be surprised at the results. They would be nice.
