Upgrade from nikon 18-140mm lens
Discussion in 'Photography Equipment & Products' started by deepind, Oct 3, 2017.
  1. Braineack
    Braineack Been spending a lot of time on here!
    Jun 17, 2013
    11,227
    4,337
    NoVA
    it would not be worth it, if you never used it. Hard for us to decide that for you.
    there is plethora of other lens you could buy. :)
  2. Designer
    Designer Been spending a lot of time on here!
    Apr 13, 2012
    16,089
    4,028
    Iowa
    Note: In the interest of full disclosure, I own a 70-300 zoom, and I like it a lot. This might be a good choice for you, although I don't think one lens will satisfy all your desires.
    This will no doubt be news to you; zoom lenses have more compromises built into them. Yes, you can get a "super zoom", or you can get a telephoto prime and get better image quality.
    Or you can "zoom in crop". Meaning; shoot with what you have, and crop later in editing to produce the frame you wanted but didn't have the reach of a long lens at the time.
  3. benhasajeep
    benhasajeep No longer a newbie, moving up!
    Top Poster Of Month
    May 4, 2006
    4,017
    494
    He may also be looking at the ultra inexpensive AF 70-300 f/4-5.6G! $170
    I have not owned or used any of them so can't say their in hand qualities or lack of.
  4. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    3,656
    471
    If you want upgrade then you should consider less "zoom" rather than more of it. The longer the zoom range the more compromise in image quality.
  5. dunfly
    dunfly No longer a newbie, moving up!
    Jan 26, 2016
    109
    32
    I don't think the D3200 will work with AF-P lenses. You need an AF-S lens. The Nikkor AF-S 55-300 mm DX was a kit lens for that camera and works well with it. Look around and you should be able to find one for around $250. Adarama even has a refurbished one for $179.95.
    Nikon 55-300mm Refurbished
    Unless you aspire to be a pro or print billboards, it should work fine.
    Be very careful with the current 70-300 DX lenses. I don't think they will auto focus with your camera and the cheap ones do not have Vibration Reduction.
    • Informative Informative x 1
  6. Frank F.
    Frank F. engineering art Supporting Member
    Oct 24, 2016
    1,829
    860
    Bonn
    Can I use an AF-P lens with my DSLR camera?
    AF-P lenses use the latest Stepping Motor technology to move the lens focus quickly and quietly making this type of lens ideal for shooting movies as well as still images. "P" in the name AF-P is derived from the pulse which drives the motor. The ability to change focus settings in the camera menu, rather than the switches on the lens barrel, offers photographers a more intuitive way to shoot.
    The first AF-P lens was introduced in January 2016, as a result the number of cameras with menu items to allow control of AF-P lenses is currently limited. Some cameras require a firmware upgrade as identified below.
    Digital SLR cameras which have no restrictions with AF-P lenses
    D500
    D850
    D3400
    D5500 (be sure the camera firmware has been updated to the latest version)
    D5600
    D7500
    Digital SLR cameras that have some restrictions with AF-P lenses
    For further details, select the product and lens combination in the DSLR camera and lens compatibility chart and check the notes.
    Df
    D5
    D600 (be sure the camera firmware has been updated to the latest version)
    D610 (be sure the camera firmware has been updated to the latest version)
    D750 (be sure the camera firmware has been updated to the latest version)
    D810 series
    D3300 (be sure the camera firmware has been updated to the latest version)
    D5200
    D5300 (be sure the camera firmware has been updated to the latest version)
    D7100
    D7200
    Nikon 1 series with the FT1
    AF-P lenses do not support other digital SLR or film SLR cameras.
  7. SquarePeg
    SquarePeg Hear me roar Staff Member Supporting Member
    Mar 18, 2013
    5,023
    2,814
    Boston
    Check out the Tamron 70-300 with VC. Good zoom lens and affordable. Comparable to the Nikon version.
    • Agree Agree x 1
  8. Solarflare
    Solarflare No longer a newbie, moving up!
    May 24, 2012
    2,637
    326
    I would recomment getting an AF-S 70-300mm f4.5-5.6 VR from the used market.
    The 55-300mm isnt worth it because it has no substantial advantages over the half as expensive 55-200mm.
    The 70-300mm on the other hand is dirt cheap on the used market and the lowest tier of Nikkor lenses which have good autofocus performance. Granted, with a D3200 you probably wont notice the difference, but should you ever upgrade, you will already have a lens for shooting sports and action.
  9. Braineack
    Jun 17, 2013
    11,227
    4,337
    NoVA
    the 55-300 was neat cause it could focus really close. but it was like the slowest focusing lens ive ever used.
    don't rule out the tamron 70-300 VC.
  10. deepind
    deepind TPF Noob!
    Nov 21, 2016
    20
    Hi all..thanks for ur kind replies..my main problem is most of the pictures I took are always blurry or grainy..even without zooming also it is grainy..can’t even see any details in pictures..is any problem with camera or lens? I have attached sample images but when u zoom and c u can’t see anything...so now am mainly using mobile camera bcos of this..it is better than this...
  11. ac12
    ac12 TPF Noob!
    Dec 5, 2017
    49
    6
    First off, WHAT are you shooting that you want "more zoom" for?
    The 18-140 lens is a decent lens with a decent zoom range.
    But zoom range has to be appropriate for the task. If you are shooting boats on a lake, the 18-140 is likely too short and you need a longer lens.
  12. Braineack
    Jun 17, 2013
    11,227
    4,337
    NoVA
    images are too small to really tell, but I think this is 100% user error.
