Upgrade from nikon d3200
Discussion in 'Photography Equipment & Products' started by deepind, Oct 11, 2017.
  1. deepind
    deepind TPF Noob!
    Nov 21, 2016
    20
    Hi,
    I have nikon d3200 can I upgrade to nikon d5300 or d5600 ? Or can I buy new lens?
  2. jaomul
    jaomul Been spending a lot of time on here!
    Feb 4, 2011
    5,551
    1,474
    Cork Ireland
    You need to give more info on what you want to achieve while also listing your lens to get any good information
  3. deepind
    deepind TPF Noob!
    Nov 21, 2016
    20
    Pictures are grainy..i hv nikon 18-140mm vr lens
  4. Dave442
    Dave442 No longer a newbie, moving up!
    Feb 1, 2015
    1,763
    423
    It's hard to tell if the new camera will solve the problem. Usually the grainy image is noise that comes from using a high ISO. The D5300 is only goes one stop ISO above the D3200, so to see a bit of improvement the D5600 is the better option.
    Another option is to pick up a fast prime lens like the 35mm f/1.8 DX lens. This can give you an extra couple stops of exposure over your current lens. Generally I would add the lens first as you can then have both those lenses when you upgrade the camera body.
    Of course, if you are shooting in really dark locations like a club, then you might not be happy until you go to a full frame camera and then you will want FX lenses. If you are not happy after that then you will just have to live with the noise, or just go to option three and buy a flash and put some light on the subject.
  5. deepind
    deepind TPF Noob!
    Nov 21, 2016
    20
    Thanks for reply...I want to take long shots and birds,nature etc...is Nikon D3200 is good for that or any other option.
  6. Dave442
    Feb 1, 2015
    1,763
    423
    For bird shots you really want to have at least 400mm. I have a the 70-300mm VR lens and can take some bird shots if they are not too far away. There are also some decent third party 150-500mm or 150-600mm lenses that will work fine with your D3200.
    There is also a new 70-300mm DX zoom from Nikon, but you would need at least the D3300 or D5300 body for it to work. This is a good lens for getting started with using a longer telephoto lens and is very portable.
  7. deepind
    deepind TPF Noob!
    Nov 21, 2016
    20
    So..can I use D3200 itself?
  8. deepind
    deepind TPF Noob!
    Nov 21, 2016
    20
    am interested in night photography including milkyway and birds ..can i buy lens to achieve this or camera body like nikond5500 0r d5600?
  9. jaomul
    Feb 4, 2011
    5,551
    1,474
    Cork Ireland
    Any new dx Nikon camera will give similar image quality as your d3200. The d5600/d7200, likely even the d500 will not substantially improve image quality due all the sensors used perform similarly.
  10. deepind
    deepind TPF Noob!
    Nov 21, 2016
    20
    Thanks..what zoom lens has good focusing ..as i try to take picture of a flying bird it flew quickly before focusing...
  11. Solarflare
    Solarflare No longer a newbie, moving up!
    May 24, 2012
    2,637
    326
    Birds are a tough subject.
    You often need very long focal lengths.
    And in flight they are very demanding to the autofocus, too.
    The D500 is a night vision wonder. Useable ISO 50k, especially if you postprocess it with noise reduction software, is definitely a huge step over useable ISO 1600 or so what an old APS-C camera will give you.
    Plus the D500 has the newest high end autofocus from Nikon.
  12. jaomul
    Feb 4, 2011
    5,551
    1,474
    Cork Ireland
    It's true the autofocus in the d500 is miles better than the d3200. Any scientific tests though place the sensor as only a fraction of a stop better iso.
    To OP, how much money are you willing to spend?
