Upgrading Nikon from-to
Discussion in 'Photography Equipment & Products' started by Sultan AlZaabi, Sep 21, 2006.
  1. Sultan AlZaabi
    Sultan AlZaabi TPF Noob!
    Sep 18, 2006
    123
    UAE
    HI THERE PEOPLE,
    i want your advice about upgrading from Nikon D70s to Nikon D200
    I want to ask you how about upgrading my body camera from
    diffirent is
    click to the image to show bigger size
    [​IMG]
    D70s
    6.1 megapixels
    AF- 5 area focus
    iso start from 200
    LCD moniter 2 inch
    little options { the options here is weak } not good options
    to show the options
    http://nikonimaging.com/global/products/digitalcamera/slr/d70s/index.htm
    [​IMG]
    [​IMG]
    D200
    10.2 megapixels
    AF- 11 area focus
    iso start from 100
    LCD moniter 2.5 inch
    more options { the options here is good } very nice options
    to show the info
    http://nikonimaging.com/global/products/digitalcamera/slr/d200/index.htm
    why i need to upgrade
    * I need more pixels and options.. not only for [ Galleries ] i'm a Graphics Designer and i want more pixels for Designing Big-Board with 6 x 2.5 mitters
    I'm waiting for your reply ..!!
    Regards
    Sultan AlZaabi
  2. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    DPreview.com is a site that most of us use for side by side comparisons. Here is a link to D70S vs D200.
    I'd wait till Photokina is over. It's a time where these companies come out with new models. You might get a better deal for the D200.
  3. PixelPerfect
    PixelPerfect TPF Noob!
    Sep 23, 2006
    63
    Boston MA
    I have the d200 i think it is really about what you are shooting if it is suitable for you or not. Purchasing the camera hot off the market i wasn't aware of the things that made the D200 not so great.
    The d200 does a thing called infringing..
    if you do not know what this is..it does not handle contrast very well.
    If you were to shoot towards a builing against the sky when you blow the piuctures up to 100% you can see the damage it has done.
    With my camera it usually wipes out parts of the edge and fills them in with birhgt blue and white.
    If you need the MP i'm assuming your printing large and the larger the print the more this infinging you will see....hence making your workflow longer to PS it out.
    It is a great potrait camera for sure.
    OH and people tell me a frimware update will take care of this infringing problem..no luck yet!
    Besides that ...the camera is kikass!:)
    Hope that helped!
  4. Tiberius
    Tiberius TPF Noob!
    Jun 19, 2006
    328
    Michigan, USA
    Pixel - what's your source on this? I've NEVER heard of this (or anythig else negative) about the D200.
  5. dsp921
    dsp921 TPF Noob!
    Oct 20, 2005
    324
    The D200 has (or mostly had) issues. Banding being the most prevalant, this being a vertical banding pattern seen mostly at transitions from highlights to shadows. Some examples would hardly show the problem and would require a few stops of overexposure (type I) others would do it under normal shooting conditions (Type III). There are also a lot of complaints of hot pixels, focus problems and some of images not being recorded. These are very well known and I can't believe anyone doing research on the D200 and not hearing about them. I think the infringing that PixelPerfect talks about it CA, and that is generally the camera's higher resolving power showing the limits of the lens used. I could be wrong, though.
    Before anyone gets too upset, there are loads of D200 shooters that don't have or haven't seen any problems and are totally happy with the camera. It's a great camera that takes great pictures, but no camera is without some issues. Banding has been showing up less since the initial units.
  6. abraxas
    abraxas No longer a newbie, moving up!
    Aug 15, 2006
    10,417
    9
    I was considering upgrading to the d200 from a d70, but have heard good things about the d80, especially that it is a better general purpose camera than the d200.
  7. JDP
    JDP TPF Noob!
    Aug 16, 2006
    285
    Minneapolis, MN
    Meh, I've heard the D80 isn't all that hot - but it does have a vertical grip OEM going for it. But yeah, it probably is a better general purpose camera then the D200, and it doesn't scream 'photographer' as much either, which I like.
    I'll be upgrading to whatever the next thing after the D200 is (D300?). Well, I should say, that's what I'd like to do - odds are I'll upgrade before that.
    The D200 has a DoF preview, which is something I'm really missing on my D50. If the D80 had a DoF preview, then I might be tempted, but if they're releasing a 10mp D80, a 14mp D200 upgrade is right around the corner. I wish.
  8. dsp921
    dsp921 TPF Noob!
    Oct 20, 2005
    324
    The D80 does have DOF preview...
