urgent advice for concert photography!
Discussion in 'Beyond the Basics' started by placeonthecorner, Jan 24, 2007.
  1. placeonthecorner
    placeonthecorner TPF Noob!
    Sep 13, 2006
    110
    Edinburgh
    hi ladies & gents!... ive been asked to shoot some pics for a band playing at the Glasgow academy in a couple of weeks and i have no idea how this works... i think theres a policy where you cant use flash... can any one just give me some general pointers?... il be using my 350d and i have 2 lenses, the 18-55mm and a 70-300mm... thanx for any help..:)
  2. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    for most concerts (the ones that i've been to)...the stage is usally light up so that flash is not required....in fact....you are sitting so far away....flash is not going to do you any good even if you use it......so if you are trying to shoot the band on the stage....you just need a snipper and take the shot.....just joking....but really.....you just use a lense with long focal length....no flash is required....the spot lights will provide enough light for proper exposure
  3. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    I suggest looking for a 'fast' lens...somthing with a large maximum aperture. The 50mm F1.8 is the usual recommendation because it's so inexpensive.
    The problem with concert photography is that it's usually quite dark. Having a lens with a large aperture will give you faster shutter speeds, which will help to keep the image from being too blurry. You may also need to use a high ISO setting, like 1600 (or 3200 (H) if your camera has it). This will cause the images to show some digital noise...but that may be something you have to accept...if you want to get fast enough shutter speeds.
  4. placeonthecorner
    Sep 13, 2006
    110
    Edinburgh
    ive actually got a press pass so il be in the gap between the barrier and the stage... but i guess your right about it being lit up, i wasent really thinking clearly there!!:)
  5. placeonthecorner
    Sep 13, 2006
    110
    Edinburgh
    ah i totally forgot i could change the iso!!...d'oh!!.. thats a great tip thanx!... unfortunatly i only have the standard lense, and the 70-300 isnt very fast...
  6. castrol
    castrol TPF Noob!
    Apr 26, 2006
    421
    Spring, TX
    It's going to be tough. Look for spots of stopped activity... like the singer
    holding a high note or something. Those will be your best bet with a slower
    lens. Shoot a lot of them, because most will likely not come out very well.
  7. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    The standard lens isn't very fast either...but at least it is easier to get sharp shots with that lens...than the telephoto.
  8. placeonthecorner
    Sep 13, 2006
    110
    Edinburgh
    ok... well il try my best... i feel an investment coming on again...*sigh*... thanx tho!
  9. mrcoons
    mrcoons TPF Noob!
    Jan 26, 2005
    55
    Illinois, USA
    Shoot in RAW that way you can tweak the exposure if need be.
  10. txshutterbug
    txshutterbug TPF Noob!
    Jul 13, 2006
    42
    Texas
    The Canon 50mm 1.8 is less than $100! Try that!:)
  11. Don Simon
    Don Simon TPF Noob!
    Jul 4, 2005
    2,484
    Unfortunately when it comes to photo gear, the conversion between US$ and £ is literally just the changing of the sign, so an $80 lens is an £80 lens. But £80 is still great for what a 50mm f/1.8 can do for you. If you don't want to buy then see if you can borrow, but I do believe fast primes are the best way to do this sort of thing without flash.
