US vs UK spec
Discussion in 'Beyond the Basics' started by ajmall, Jan 4, 2005.
  1. ajmall
    ajmall TPF Noob!
    Mar 24, 2004
    656
    Leicester, UK
    whats the difference in spec on a 20D? are we just talking plugs here or major differences?
  2. ajmall
    ajmall TPF Noob!
    Mar 24, 2004
    656
    Leicester, UK
    anyone?
  3. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,190
    22
    Hollywood, FLA USA
    I do not know why there would be anything differ in the spec of the two visions
    The only likely differs are the warranty and packaging
  4. ajmall
    ajmall TPF Noob!
    Mar 24, 2004
    656
    Leicester, UK
    i'll ask some shops as no-one really has a clue herer. i can get international warranty no problem and different packaging is not really an issue... so far, so good
  5. Daniel
    Daniel TPF Noob!
    Jun 14, 2004
    189
    Dublin
    There is no difference at all. Battery charger of course won't fit in UK plugs, but runs with 240V as well.
  6. mrsid99
    mrsid99 TPF Supporters Supporting Member
    Mar 8, 2003
    2,964
    5
    Florida
    The charger plug is a two-pin type and will fit in a shaver socket, I believe that a cheap adaptor is available.
  7. Jeff Canes
    May 19, 2003
    6,190
    22
    Hollywood, FLA USA
    The charger is rated for AC 100 - 240v, 50 - 60Hz. And the cord is removable you should be able just to replace it ? right
  8. mrsid99
    Mar 8, 2003
    2,964
    5
    Florida
    I assume you mean the "cord" is removeable and yes you could just get a replacement with the 13amp UK plug one end and the two-pin that plugs into the charger the other but the simplest and cheapest is what I previously suggested, i.e. get one of those adaptors that plug into the 13amp wall socket and has a two-pin socket on the back (same as a wall shaver socket) and then plug the standard charger plug into that.
    Alternatively just look for bathrooms in the UK with shaver outlets!
    As goes the voltage, you're correct in that the charger has wide range input capability and will run on either 115vac 60Hz or 240vac 50Hz.
    HTH.
  9. ajmall
    ajmall TPF Noob!
    Mar 24, 2004
    656
    Leicester, UK
    finally some answers! thank you!
us vs uk specificatio
