Use a TTL flash Manually ...
Discussion in 'Beyond the Basics' started by elrafo, Sep 24, 2008.
  1. elrafo
    elrafo TPF Noob!
    Jun 9, 2004
    169
    montreal
    Hello there,
    I have a SB-600 but would like to use it with my old Hassy. I have the sync stuff, my concern is more how to calculate exposure, power of my flash.
    In the old ones I could read distance according to Iso/F-stop, how does it work with this brand new flash without buying a expensive flash metter ?
    thanks!
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    It does have a manual mode, doesn't it?
    At full power, it has a Guide Number of 30m at ISO 100 (at 35mm zoom head position).
    To calculate exposure, divide your guide number by the distance to the subject, to get the aperture value. So at 3.75m distance to your subject, you would use F8 (with ISO 100 and flash at 35mm zoom and full power).
    Adjust accordingly for different variables.
  3. elrafo
    elrafo TPF Noob!
    Jun 9, 2004
    169
    montreal
    sure it has manual mode!
    thanks a lot for your advice.
    Can we say that with 400 Iso 120 m? seems wiered to me...
  4. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Not quite. Light fall off is an inverse square to the distance, so as the distance doubles, the light drops to 1/4.
    Do you have a DSLR camera? You could use that to test your flash exposure before using up film in the Hassy.
  5. elrafo
    elrafo TPF Noob!
    Jun 9, 2004
    169
    montreal
    oh thanks that's more complex indeed. I would love to know if it is possible to find a chart table with distance on this flash, there is not such of things in the manual.
  6. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    It might be built into the display...check that out.
  7. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Get a light meter. There is no histograms on a Hassy and the integrated meter cannot meter a flash.
    Meters can go from $50 on up. Then there is NO guessing. ;)
  8. elrafo
    elrafo TPF Noob!
    Jun 9, 2004
    169
    montreal
    Hey ;)
    this could look stupid but I never used a meter with flash, only for ambiant lighting, I have a lunasix III S, is it useful also for flash photography ??
    I guess you mean flash meter but I never used this kind of tools...
  9. JerryPH
    Oct 14, 2007
    6,111
    15
    http://www.marquis-kyle.com.au/Lunasix3.pdf
    http://www.gossen-photo.de/english/...six3.html,picts/navi_foto_sub_01_lunasix3.gif
    I do not think so, it looks to be a reflection/incident light meter. You need the ones that can tell you the highest point touched after a flash and hold that position automatically. Yours will tell you what the light is as long as you hold it "on" and by the time you react to a flash, its gone up... and down.
    Now I am not an expert on this unit, so of course I could be wrong.
  10. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    Why not use the guide number for free?
  11. elrafo
    elrafo TPF Noob!
    Jun 9, 2004
    169
    montreal
    I could if I had a table with correspondances between Iso - f/stop - flash power.
    Can I calculate with the Guide number what will be my limit distance on a TMAX 400 Iso with an 8 aperture ?
  12. JerryPH
    Oct 14, 2007
    6,111
    15
    Because there are variations from flash to flash, you are kinda guessing then.
    If you do not want to get a meter, why not use your D200 in manual mode to get a "feel" of what settings are good at what apertures, write that down and use that as the basis for starting points? Just take a pic and when well defined, write down the settings and transfer those settings to your Hassy. ;)
    I would trust that more than using the guide numbers from the manual.
