using grey card
Discussion in 'Photography Beginners' Forum' started by mathews, Jul 15, 2010.
  1. mathews
    mathews TPF Noob!
    Jul 6, 2010
    15
    india
    what is the lighting conditions most suitable for using the grey card. can i use it in bright sunlight to get a meter reading or in shadows. is an overcast day all right for using a grey card. please help.
  2. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    Any lighting condition is suitable for using a gray card. That's the point of the gray card.
  3. shmne
    shmne No longer a newbie, moving up!
    Jun 3, 2009
    641
    83
    Florida
    The beauty of the gray card is that regardless of what colors are lurking around the world, you can trust that your card will stay the same color within its life span.
    This lets you say, regardless of light, that that card is gray. When you are in photoshop this means that you can use the curves adjustment to color correct your scene by using that card (as well as a source of white and black in the scene)
  4. Boomn4x4
    Boomn4x4 TPF Noob!
    Mar 15, 2010
    766
    4
    Ohio
    ^ +1
    What you are asking is the same thing as, "what temperture is ideal to use a thermometer?"
  5. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    basically your cameras meter renders everything 18% grey, (not 12%), green as in grass, is also mid range in colour, hence why a reading from grass or a grey card will give correct exposure for the lighting in the scene you shoot, as long as the reading was in the same light and as long as you lock exposure on the card or grass before firing at the subject. Once you grasp the basics of the meter, (being a liar basically) then you know to overexpose for whites, dependent on how bright the scene is, 1, 2 ,3, stops etc or underexpose by similar for darker colours and shadows. H
  6. mathews
    mathews TPF Noob!
    Jul 6, 2010
    15
    india
    but doesn't colour change under different lighting conditions.
  7. Boomn4x4
    Boomn4x4 TPF Noob!
    Mar 15, 2010
    766
    4
    Ohio
    You aren't metering "color"... you are metering available light. The color is irrelevant. Blue can reflect 18%, red can reflect 18%, yellow can reflect 18%... you could just as well use an 18% red card, and 18% blue card, or an 18% yellow card... people just use gray because its a simple color to make.
    Your exposure dosen't have ANYTHING to do with the colors, it has to do with how much light is available.
  8. mathews
    mathews TPF Noob!
    Jul 6, 2010
    15
    india
    red is 18%. yellow is one stop lighter than red so it cannot be used as a grey card.
  9. Bitter Jeweler
    Bitter Jeweler Been spending a lot of time on here!
    Apr 27, 2009
    12,984
    4,976
    Cleveland, Ohio
    the internets is full of experts
  10. Willl
    Willl TPF Noob!
    Dec 26, 2009
    49
    CT
    Yeah that's why everything on the internet has to be true.
  11. mathews
    mathews TPF Noob!
    Jul 6, 2010
    15
    india
    to be frank, i am totally confused myself.
  12. Boomn4x4
    Boomn4x4 TPF Noob!
    Mar 15, 2010
    766
    4
    Ohio
    There is no reason you cannot have a shade of yellow that reflects 18% of light.
