Using only manual ?
Discussion in 'Photography Beginners' Forum' started by Sirene, Aug 23, 2009.
  1. Sirene
    Sirene TPF Noob!
    Aug 18, 2007
    229
    Canada
    Do pros only use manual or also TV and AV ?
    Thanks
  2. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    I'm not a pro. I think most pros use whichever works best for the particular situation though. If I had to guess, I would say a lot of Manual mode, but a good amount of Aperture Priority as well.
    I personally use Manual almost all the time. Sometimes I'll switch it to Av though.
  3. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    they use what ever it takes to get the job done and have even been known to use auto or program mode. The difference is they know what those options will do for the image and the situation.
  4. choudhrysaab
    choudhrysaab TPF Noob!
    Jul 11, 2009
    667
    Toronto, Ontario. Canada
    i guess its your own comfort level. some prefer total manual mode where others would prefer one setting automatically set and just play with the other settings i.e. Av/Tv Mode.
  5. Plato
    Plato TPF Noob!
    Jul 11, 2009
    1,058
    United States of America
    It's kinda like I've told my children when teaching them to drive. There ain't nothing wrong with an automatic transmission as long as you're aware of what it's doing.
  6. moze229
    moze229 TPF Noob!
    Jul 3, 2009
    47
    Raleigh, NC
    I would agree with ann - whatever it takes. But I would also tend to believe a pro would move towards manual mode mostly because a pro will know which settings to use instantly to produce the intended result. I use manual and Av, but not because I'm a pro. :) I've just used them since I've had my camera from day one. It's the best way, in my opinion, to learn. Of course, I also have the luxury of taking a shot 100 times if I need to because I don't shoot anything for clients. I've also read a few photographers using aperture priority exclusively except for weird situations. Just depends I guess.
    Matt
  7. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    Whatever works. Manual in house for when you can control the envinronment, some form of automatic when you at least know one factor you want to remain static (aperture for instance). All of these modes are tools for someone who knows their limitations and their strengths.
  8. Craig J
    Craig J TPF Noob!
    Aug 15, 2009
    75
    Fort Worth, TX
    I use manual quit often, but I learned in manual. I often use it at night and in low light because it is easier than trying to read the control panel.
    I also shoot manual only film cameras.
    I also suggest to anyone starting out to learn manual because it teaches you "why" you do something and not just "how" to do it.
    (I am not a pro)
    Craig
  9. Sirene
    Sirene TPF Noob!
    Aug 18, 2007
    229
    Canada
    Great, thanks guys !
  10. mariusz
    mariusz TPF Noob!
    Aug 20, 2009
    97
    Toronto
    manual settings will give you greater control of the lighting (I use it 90%) however the auto settings are use full in some situations ie fast shooting and changing light conditions.
  11. inTempus
    inTempus TPF Noob!
    Dec 15, 2008
    3,692
    4
    Indiana
    I've recently been anointed as a "pro" by Village Idiot and Rufus. So let me chime in.
    I shoot manual mode only when in studio or on location with studio lighting. There are rare occasions where I shoot manual without studio lighting.
    Generally you'll find my camera set to Av mode. I pick the depth of field I want (aperture) and I let the camera pick the shutter speed. This is great for static to semi-static subjects.
    If I'm in a situation where I'm trying to stop motion or control the motion blur, I'll switch to Tv mode and set my shutter speed and let my camera determine the aperture setting.
    I never use auto ISO.
    Hope that helps.
  12. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,700
    68
    Missouri
    Early in my pro career, I shot manual because... well... Nikon F's and F2's didn't HAVE any automatic on em :)
    Later, I shot aperture priority for static stuff and shutter priority for sports.
    Full manual for everything involving studio lighting (obviously).
    Now that I am not a pro any more, I virtually NEVER shoot manual when not using strobes, simply because I don't see the point in it when you are not using an external light meter. If you are hand metering, OK, then I get it... but if you are using the camera's meter anyway, all you do when shooting manual is add steps to the process IMHO... I shoot aperture priority and shutter priority 99.9 percent of the time when above water.
    Below water, I shoot manual (dual strobes) all the time.
