Using Photoshop CS1 to achieve HDR?
Discussion in 'HDR Discussions' started by TobascoJackson, Nov 9, 2009.
  1. TobascoJackson
    TobascoJackson TPF Noob!
    Nov 8, 2009
    36
    Utah
    I understand the exposure techniques required to get images for an HDR photo, but everything I've read says that you need a third-party program or Photoshop CS2 (or higher) to process these images and combine them into a single HDR photo.
    I only have CS, and I was wondering if there was a "manual" way to do it?
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    It may not be (what has now become known as) HDR...but you can certainly combine multiple images to achieve a higher dynamic range for your image.
    Simply layer your images into a single Photoshop canvas, then use layer masks to hide/show the areas that you want.
    It will be quite helpful if the images are the same (besides exposure), so using a tripod will really help. You can manually align the images but that can be a PITA.
  3. Foques
    Foques TPF Noob!
    May 21, 2008
    219
    Mundelein IL
    I had a decent luck using layers, and marking them to be an overlay.. try playing with that.
  4. TobascoJackson
    Nov 8, 2009
    36
    Utah
    So did you take a regular exposure as the bottom layer at "normal" blending mode, then layer the high and low exposures on top of it in "overlay" mode?
  5. Foques
    Foques TPF Noob!
    May 21, 2008
    219
    Mundelein IL
    pretty much.
  6. boogschd
    boogschd TPF Noob!
    Mar 19, 2009
    606
    ph
    i can get you photomatix if you want
  7. TobascoJackson
    Nov 8, 2009
    36
    Utah
    How much does it cost new? I'm on a Mac, btw.
