Using the flash for lighting without camera
Discussion in 'Photography Beginners' Forum' started by akazoly, Mar 16, 2008.
  1. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    Is possible to use a flash without camera for continuous lighting ?
    I have some old flashes and I need a good light, something around 5000-6000K.
    Is possible to remove the bulb from flash and use at some voltage ? like a normal bulb ?
    Thanks!
  2. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Best bet are home depot halogen lights. They're hot, and you can use gels to get them to the color temperature you want.
  3. Tiberius47
    Tiberius47 TPF Noob!
    Oct 4, 2007
    742
    46
    You want to use a camera flash as a torch?
    Flashes aren't designed to be on constantly. They overheat and can explode.
  4. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    What is the gell ?
    BTW, when I use a different color temperature (for example: 6500, 7000, 8000) and shooting with RAW is possible to set the white balance as 5000K bulb ?
  5. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    A gel is a colored sheet that you put between the light source and your subject for color effects or compensations.
    eg. You're shooting indoors with tungsten film and a flash on top of your camera, you gel the flash to tungsten to match the lighting and so you keep the color consistent.
    With the RAW thing, Yes, after the fact.
  6. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    No you cannot. A flash was designed to flash for VERy short durations.
    If you need a flashlight, go to a hardware store and pickup a $4 flashlight. If you want continuous... wel, my thoughts about using continuous light for photographic purposes is pretty well known. I am against it. If you need to find out why I am against it, just do a search here. :)
  7. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    No. What you are looking for is a lamp.
