UV filter affecting image quality...
Discussion in 'Beyond the Basics' started by elrafo, Mar 29, 2008.
  1. elrafo
    elrafo TPF Noob!
    Jun 9, 2004
    169
    montreal
    Hey there,
    I bought a brand new UV filter for my nikon 50mm f 1.8 and for my sigma 17-70. I thought it was the best protection for my front glass and wouldn't affect Image quality, but it does!
    what do you do when you want to shoot portraits with candles for instance ? I keep on having ghosty pictures (duplicated image of the light sources offseted on the top right of the picture. Same problem with high contract image, a bright specular on a reflective object or a window overexpoded for instance.
    When I remove the filter, photos are clean, sharp and highlights are not offseted.
    I suppose that people who buy a 6000 $ Leica 50 mm f1.0 will buy a lens protection, but if it affects the image like me, it is not a good solution!
    is there an alernative way to protect your lens without having this kind of troubles ?
    thanks!
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    What filter did you buy? They vary greatly. It's lens protection. If you're careful you don't need it. Is it really that hard to screw it off when you need to shoot into the light?
    For the record every piece of glass will create a reflection into the lens. Flat glass like filters are the worst and even though a Hoya SHMC Pro filter will not reducing image quality, if you shoot in to the light it will ghost (but not flare)
    Comparison of filters was done here: Follow the link in that thread for yet another comparison. http://www.thephotoforum.com/forum/showthread.php?t=100830
  3. elrafo
    elrafo TPF Noob!
    Jun 9, 2004
    169
    montreal
    thanks for your test! actually it is the same problem, and I own a Hoya too... must be a bad coating. I will check if some UV filters have better reaction to light!
    thanks!
  4. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    If your only purpose is lens protection, you should purchase a "protector" filter. Clear glass!
    Unfortunately, in all cases (including the protector), you're adding glass surfaces, flat glass surfaces. Purchase absolute top of the line filters (for better multicoating), for example, Hoya Pro-1 series and always use a hood!
  5. MX962
    MX962 TPF Noob!
    Mar 3, 2008
    225
    "IDAHO"
    over 20 years and never had the need for a filter in any form except for ND's and such and believe me my equipment goes through hell
  6. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    You don't use polarizers?
    By the way, forty years and, yes, I have needed protection for my lenses.
  7. MX962
    MX962 TPF Noob!
    Mar 3, 2008
    225
    "IDAHO"
    Yesssss I use them ,thats why i said "and such" :) gotta be so technical ! ha.You know i used to use them some time ago but i have had so much better luck on the higher end glass with nothing on it that i basicaly use all my old filters for coasters on the coffe table now ,I had a Sigma 28-80 3.5 go down a lava cliff about 7 years ago fell tumbling bouncing it was horible for about 400 feet almost split the housing rite open and beat all edges down you could see where the rocks had hit the lens several times later i had cleand the lens off all but one nick in the lens cleaned up i was totaly shocked that was it
  8. Village Idiot
    Mar 20, 2008
    7,274
    406
    B+W FTW
  9. Dubious Drewski
    Dubious Drewski TPF Noob!
    Jan 18, 2008
    909
    4
    Lethbridge, Alberta, Canada
    I recently learned the harm of having a cheap filter on the end of your lens.
    For this shot here. I was getting this strange artifacting.
    When I mentioned this, she (Also an avid photographer) suggested I take off
    the cheap Tiffen UV I had on the end of my lens. That did it! Lesson learned.
  10. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    That is ghosting not a strange artifact. The very bright light source is flipped vertically and horizontally through the optical axis of the lens. All flat pieces of glass attached to the front of a lens cause this, but only when shooting into the light.
    So yeah protection is good, but as soon as I do anything involving light sources which appear within my frame I take mine off.
do filters affect image quality
do uv filters affect image quality
do uv filters affect picture quality
do uv filters affect the quality of photos
does a uv filter alter image quality
tiffen uv filter
uv filter affect image quality
uv filter and image quality
uv filter image quality
