Uv Filters
Discussion in 'Beyond the Basics' started by MPowerM3, May 20, 2006.
  1. MPowerM3
    MPowerM3 TPF Noob!
    Mar 19, 2006
    239
    Ct, USA
    Will shooting with my Uv filter (polarizer thingy) on be causing my night shots and low light shots to come out darker then they should be? I notice a lot of my shots come out darker with it on. Am I right?
  2. duncanp
    duncanp No longer a newbie, moving up!
    Nov 15, 2005
    3,390
    43
    Sheffield
    UV Filters and Polarisers are completely diferent btw, so i dont really know which one you mean..
    A UV filter is pure galss and wouldnt effect the duration of an exposure or the actual exposure itself...
  3. tasman
    tasman TPF Noob!
    May 7, 2006
    468
    Edmonton, Alberta, Canada
    There is a difference between a UV filter and a Polarizer filter. UV's are usually clear some have a very slight pink tint. They do not change the light coming in to the lens by any real amount, so you can keep it on the lens all of the time.
    A Polarizing filter is dark. It is meant to cut the light from bouncing or reflecting from surfaces, for example you would use it in bright sunlight near water or anything reflecting lots of sunlight causing glare. It will also change the f stop by one half or more depending on the filter or the amount of light. I would not use it at night.
    I keep a UV filter on as a lens protector. If something hit the front of my lens the filter might be damaged but not the lens.
  4. MPowerM3
    MPowerM3 TPF Noob!
    Mar 19, 2006
    239
    Ct, USA
    Thanks for the respose tasman I use mine the same way, so if i am shooting in bright lights with no glare the polariser would do no benefit right, only in high amounts of glare?
    It is a UV filter then, as it is pure glass, what would a polariser to then? Sorry for the noob question.
  5. tasman
    tasman TPF Noob!
    May 7, 2006
    468
    Look at my last post.
  6. duncanp
    Nov 15, 2005
    3,390
    43
    Sheffield
    a polariser would saturate naural colours darken blue skies to make white clouds stand out more and remove reflections of object. they usually can rotate to increase / decrease the amount of the effect that takes place,
    sorry if that didnt make any sense...
  7. duncanp
    Nov 15, 2005
    3,390
    43
    Sheffield
    lol i didnt see your last post either....
  8. tasman
    tasman TPF Noob!
    May 7, 2006
    468
    It might enhance color.
    Do you have a pair of sunglasses that might be polarized? It is about the same effect. just trying to give you an example.
  9. duncanp
    Nov 15, 2005
    3,390
    43
    Sheffield
    my polariser saturates the colour and a just presumed that that woulf generally happen with all polarisers...
  10. tasman
    tasman TPF Noob!
    May 7, 2006
    468
