Vertical shutter release
Discussion in 'Photography Beginners' Forum' started by d60pictars, Nov 4, 2008.
  1. d60pictars
    d60pictars TPF Noob!
    Nov 4, 2008
    Hello, I am a new Nikon user and I have a question. I was looking a battery grip for my D60 and I was wondering what does vertical shutter relese mean.
  2. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Extra shutter release button for your camera when you taking a photo with your camera in Portrait orientation.
  3. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
    Welcome to the forum.
    That's correct. Most battery grips come with an extra shutter release button (and usually a control dial etc) on the lower right corner, so that when you rotate the camera, you can keep your right hand in a comfortable position rather than having to turn it with the camera.
  4. dEARlEADER
    dEARlEADER TPF Noob!
    Apr 9, 2008
    1,312
    Canada
    I don't mean any disrespect but if ur asking this question you most likely don't need a vertical grip and should instead dump that money into another lens, tripod, or something that will excel your photography.
    /end run on sentence
  5. d60pictars
    Nov 4, 2008
    I want just it for the extra battery power. The battery in my D60 doesn't seem to last long, then again I don't use it everyday.
  6. rlcphotos
    rlcphotos TPF Noob!
    Nov 23, 2007
    197
    Western Pa.
    its true one doesnt really need the battery pak,,but I find with me the extra weight gives me a firmer grip with less shake, just one mans opinion..I guess:lmao:
  7. dEARlEADER
    Apr 9, 2008
    1,312
    Canada
    wow... when i had the d60 the battery seemingly lasted forever.... and i'm a resource hog who leaves my display/meter on for long periods...
    the battery should drain very little in between usage..... maybe you have a bummer battery or you use the in camera flash a lot...
    either way you could save money by simply buying another battery...
  8. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
    I have the Canon XTi ... and the battery that shipped with the camera last pretty long. (as well as the non-oem one I bought) If your battery lose all the power very quick, you may want to check with Nikon (if under warranty). Even with the battery Grip, if your original battery has problem, you may not want to used the problem battery with it.
  9. d60pictars
    Nov 4, 2008
    The thing is that I don't use the camera very often maybe once or twice a week (roughly 20-50 shots). When I do use it I notice that the battery life display drops 2 or 3 bars within a couple of minutes. I have to charge the battery about once a month with this usage. Is this normal?
  10. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    well, that's getting as many as 400 shots per charge which is relatively ok, though it should be better... I would think.
canon shutter release button vertical
o que vertical shutter
shutter vertical
vertical release shutter
vertical shutter
vertical shutter release
vertical+shutter release
what is a vertical shutter release
what is a vertical shutter?
what is vertical shutter release
