Viewfinder Question
Discussion in 'Beyond the Basics' started by Smith2688, Jun 19, 2005.
  1. Smith2688
    Smith2688 TPF Noob!
    Jun 18, 2005
    231
    The Island
    I was reading the manual for my Chinon CE-4 online, and I was wondering what it meant about the viewfinder whent it said:
    Viewfinder - CE-4: Fixed eye-level pentaprism, central split image with microprism collar and ground glass
    I know what a pentaprism is, but what's the italicized part mean?
  2. ThatCameraThingy
    ThatCameraThingy TPF Noob!
    Jun 11, 2005
    275
    Bloemfontein, South Africa
    Hey Smith#### (can't remeber those nr's)
    I Believe what the italics refer to is the focusing screen.
    If you look through the Fiewvinder and see a round spot in the middle with a split image and the rest of the images has concentric lines around the middle then I belive you have Split image microprism (center part) and Groundglass (concentric part).
    This is an educated guess.
    Any one welcome to porve me wrong.
    Hanno
  3. will965
    will965 TPF Noob!
    Nov 27, 2004
    214
    England
    Yeh that camera thingy is right. The viewfinder is split and has a circle of ground glass to help you focus correctly (when the center is out of focus you will notice the image is slightly shifted diagonaly up or down and when the image is in focus it will be central). (I think anyway...)
  4. Smith2688
    Smith2688 TPF Noob!
    Jun 18, 2005
    231
    The Island
    Thanks both of you! You better learn those numbers TGT or or or...
    Will - you're right about the OOF bit. Thanks a lot...now I don't need to rely soley on how it looks haha...that was a little annoying after a while.
    Lemme ask you, do you know what it means when the bottom half of the circle turns black? What about when the top half turns black?
  5. DocFrankenstein
    DocFrankenstein Clinically Insane?
    Apr 29, 2004
    1,646
    6
    Yeah, it means you're using a long and/or slow lens and the split circle is useless. You'll have to focus on the groundglass with long/slow lenses.
    My guess is that it happens the most with your Auto Promaster Spectrum 70-210mm f/3.8 lens.
    That's normal. Learn to live with it.
  6. Smith2688
    Smith2688 TPF Noob!
    Jun 18, 2005
    231
    The Island
    hah! You're right it does happen more with the telephoto. However, I can make it happen with the 50mm prime if I make the f/stop smaller and press the DOF preview button. I thought it might be for exposure? or would it still be for focusing and I just can't use the split circle for focusing with small f/stops?
