vignette
Discussion in 'Photography Beginners' Forum' started by Hiseyes, Jul 14, 2010.
  1. Hiseyes
    Hiseyes TPF Noob!
    Jul 13, 2010
    19
    Hello,
    Via Gimp, I've attempted adding the vignette to photos with no success, though I came close once. So far the final result has not been to my satisfaction. I've not purchased anything from photoshop, but I'm wondering if I need to make the plung and get either lightroom or elements. Is there a free program that is somewhat user friendly and effective?
  2. BuS_RiDeR
    BuS_RiDeR No longer a newbie, moving up!
    Oct 29, 2009
    2,356
    82
    Riverview, New Brunswick, Canada.
  3. Hiseyes
    Hiseyes TPF Noob!
    Jul 13, 2010
    19
    Thanks so much. So far, it isn't working. :(
  4. BuS_RiDeR
    Oct 29, 2009
    2,356
    82
    Bummer... Sorry...
  5. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    Dude, vignette is easy to do.
    Create new layer, get a brush that is soft (0% hardness)
    and paint around the edges
    lower opacity as you need
  6. j-digg
    j-digg TPF Noob!
    Jan 3, 2009
    476
    15
    Minne-snow-ta
    My way in Gimp:
    Create a new layer if you so choose...
    Use elipse select...
    Make an elipse within the image, the circle is the guideline for where the darker edges of the vignette will be.
    Click Select>Invert
    then
    Select>Feather ( input a logical amount of pixels in comparisson to the image size )
    Select Paintbrush Tool ( Adjust opacity as desired )
    Paint in the corners of the image...
    Play around with that if you can follow it, and you should be able to achieve the effect youre looking for.
  7. Hiseyes
    Hiseyes TPF Noob!
    Jul 13, 2010
    19
    Thanks so much for this advice. I think I need Gimp for Dummies... :( But I'll keep trying.
  8. j-digg
    j-digg TPF Noob!
    Jan 3, 2009
    476
    15
    Minne-snow-ta
    You try my method? Ill be online for awhile if you need help, I could help you walk through it.
  9. Hiseyes
    Hiseyes TPF Noob!
    Jul 13, 2010
    19
    j-digg, yes I tried your method. Thanks so much for checking in. I might be able to give it another try later today.
  10. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    Isn't it kinda hard to get it nice and even that way though?
  11. Hiseyes
    Hiseyes TPF Noob!
    Jul 13, 2010
    19
    Getting it even is one of things that I have a hard time with.
  12. fokker
    fokker No longer a newbie, moving up!
    Jun 23, 2009
    2,830
    294
    New Zealand
    Just FYI lightroom isn't really designed as an editing program in lieu of photoshop, it is a cataloging/organizing program with some basic editing ability built in.
