Vignetting
Discussion in 'Beyond the Basics' started by danalec99, Sep 28, 2004.
  1. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    How can we get the vignetting effect intentionally without the assistance of PS?
    Example 1
    Example 2
    I'm not if he used PS for the effects in Example 2
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Put on a filter, step-down ring or lens hood that is the wrong size.
  3. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    you sure? :)
  4. SWFLA1
    SWFLA1 TPF Noob!
    Aug 23, 2004
    241
    danalec -
    if you have any circular rubber lens hoods - try one with a wide angle lens - or a zoom set to its widest angle. If the hood is the incorrect size, you should get vignetting in the finished product.
    It's a fun effect to play with..
  5. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Just use PS :p It's easier to control the outcome to get exactly what you want.
  6. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    Thanks everyone! :)
  7. Canon Fan
    Canon Fan TPF Noob!
    May 28, 2004
    1,125
    7
    Purgatory, Wisconsin
    I have actually used black construction paper from an office supply store taped onto my existing hood for a makeshift sorta "vignette enhancer" in the past. The nice thing about that is you can vary the length and effect of it for almost free. You may need more than one piece though to make sure light isn't entering through the paper or you'll get wierd color casting (unless shooting BW which was when I did it about 14-15 years ago in High School photo 101)
    Otherwise I'd say PS it. Thats pretty much how I do all of mine now. Much more control albeit "unpure".
  8. jadin
    jadin The Mad Hatter
    Feb 18, 2004
    1,740
    9
    Down the Rabbit Hole.
    Looks like burning to me...
    If it's not being burned in photoshop, could be when it's developed no?
  9. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    Wondering if someone could offer a tutorial on Vignetting in PS!?
  10. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Make a new layer, ctrl-A (select all), select/modify/border, depends on your image size, for an 800x600 image I'd say around 50 pixels. Then feather the selection (ctrl+alt+d) by half the amount of your border and then fill it with black (alt+backspace). Voila. Adjust opacity as desired. Try changing the blending mode as well.
  11. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    Thanks Matt, I'm sure its tougher than it sounds like :); will get back to you if I need further assistance!
  12. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Real vignettes look much better IMHO. The PS vignette is on par with the PS lens flare.
