Vintage 8x10
Discussion in 'Collector's Corner' started by PNA, Aug 14, 2006.
  1. PNA
    PNA TPF Noob!
    Mar 12, 2006
    2,771
    Wave when you see me go by.....
  2. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    so thats how you build one that will do all that. Its window hardware and desk hinges lol.
  3. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    what does swing do to the image?
  4. mysteryscribe
    Feb 1, 2006
    6,071
    supposed to change the fucus on horizontal images like when you shoot a long building to get it all in focuse.
    I think
  5. Jeff Canes
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    That would be the opposite of tilt right?
  6. mysteryscribe
    Feb 1, 2006
    6,071
    tilt should be for verticle objects to get them in focus at once or so it says. I haven't had much occasion to use it with my cameras since I use them in a small studio setting. I also shoot long depth of field as well.
  7. Jeff Canes
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    I thought that was shift
  8. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    Tilt is vertical swing; swing is horizontal tilt. Tilt and swing change the angle of the lens/film plane.
    Shift is moving the lens or film standard left or right horizontally, but still maintaining the same plane. Rise is like shift, but up and down.
    Tilt and swing affect both perspective and the plane of the DOF. Usually the front standard is manipulated to affect the plane of the DOF, and the rear standard manipulated to affect perspective, but it is possible to use either standard to do either effect, it's just a method to help keep things straight when you are twisting the camera around.
    The perspective effect can be demonstrated in the darkroom by looking at how an enlarger projects an image onto the easel. Raise one side of the easel and that side of the image will stretch out. This is how swing and tilt work.
    Shift and rise are used to control what area of the coverage of the lens is positioned over the ground glass/film area. If your lens has lots of coverage, like an 8x10 lens on a 4x5 camera, you could really go crazy. If your lens only barely covers 4x5 (like most press lenses), then you won't be able to rise and shift as much before you encounter the edges of the lens coverage.
    What is important is the relationship between the front standard and the rear standard. For instance raising the front standard is the same as lowering the rear standard. Or if you swing the front standard to the left, and then swing the rear standard the same amount to the left, the lens plane and the film plane will be parallel, and the effect would be the same as a rear shift to the right, or a front shift to the left.
  9. nealjpage
    nealjpage multi format master in a film geek package
    Sep 16, 2005
    3,479
    Oregon
    Isn't that awfully expensive without a lens? Or are they exceptionally rare?
  10. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    I'm not up on specifics between Deardorff models, but I think $1250 is probably about right in the middle of the price range for a Deardorff 8x10. A pretty beat up one with ugly bellows patches, cracked ground glass, etc... could go for a lot less. Like new ones go for a lot more. This one looks sound mechanically, although the seller's description of outstanding cosmetic appearance is a little overstated.
