Wacom tablets...
Discussion in 'Photography Equipment & Products' started by hacksaw35, Aug 19, 2007.
  1. hacksaw35
    hacksaw35 TPF Noob!
    Jan 10, 2007
    114
    USA - Kansas City
    I am in my first year of school as a graphic designer, and I would like to get an intuos wacom tablet...I am working on a 20" imac, and was wondering whether I should just get the 4x6, or go for the 6x8...the 6x8 also has double the mouse buttons...not really sure what the advantage of that is? Thanks.
  2. droyz2000
    droyz2000 TPF Noob!
    Jun 17, 2006
    304
    Buffalo, NY
    IMHO, I would go with the larger of the two. I have only played around with Wacom Tablets but there is a learning curve and the mouse must be used on the tablet which can be annoying until you get used to it. When I was using the tablets I felt that the more real estate that I had, the more control I had.
  3. soylentgreen
    soylentgreen TPF Noob!
    Feb 27, 2007
    735
    Miami, FL
    Definitely go with the largest size you can afford. You will find the freedom of movement and stroke capability of larger work surface a real benifit. I actually use my tablet as a mouse pad for the Intuos mouse when I am not using the pen. Also, if you are using a widescreen monitor, make sure to get a widescreen tablet.
  4. Digital Matt
    Jan 30, 2004
    5,346
    65
    Santa Barbara, CA
    I myself don't use the mouse on the tablet. I prefer a normal USB mouse next to the tablet. The larger the tablet, the finer the control.
  5. hacksaw35
    hacksaw35 TPF Noob!
    Jan 10, 2007
    114
    USA - Kansas City
    So everyone thinks it's worth it to get the larger tablet. OK.
    One more question...Is there any good books about using these tablets with CS3, or is it kind of just through practice?
  6. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    345
    North New Jersey, United States of America
    I have an older smaller Wacom. I use the mouse for most photoshop activities but for fine detail work, the Wacom is pleasant to use. However.. a pain to use with dual monitors.. hopefully they have improved on their multi-monitor support.
  7. Bigger = Better.
    No books available.
  8. Jon, The Elder
    Jon, The Elder TPF Noob!
    Jul 10, 2007
    376
    Southeastern Michigan
    I use the 6x8, but scale down the tablet area so I have a minimum of hand/wrist movement.
    I don't use the pen pressure feature, so be sure to modify your brush characteristics if you do the same.
  9. soylentgreen
    Feb 27, 2007
    735
    Miami, FL
    No, there are no books that I know of. Pretty much learn as you go. You will customize the buttons, pressure sensitivity, work area, etc. to suit your own needs. That's pretty much it. Just think of it as a mouse that you have been using all this time with the added benifit of pressure control, like a pen, to control strokes & brushes as you draw, and more precise control in minute details.
wacom tablets sold in miami
