Want to use a wireless trigger with A57 and 2 yongnuo 560 II ..........hotshoe??
Discussion in 'Sony Accessories' started by MetroRuss, Mar 10, 2014.
  1. MetroRuss
    MetroRuss TPF Noob!
    Feb 15, 2013
    88
    5
    BC Canada
    Hello,
    I have been searching for a few days now about which wireless trigger can work with my A57 proprietary hotshoe.
    Can someone please let me know if my thinking of the setup is wrong.
    I am planning to use the flashes to take some interior real estate photos with a sigma 10-20mm, the window brightness is really blowing out a lot of my pics.
    Here is what I am thinking:
    Can I use a sony hotshoe adapter and then use any type/brand/model of wireless no TTL trigger to fire off 2 remote off camera flashes (YN-560II) and since the receivers will have the standard hotshoe can I use the less expensive canon/Nikon version since I do not plan to use these flashes mounted to my a57.
    If this setup above does not work, would I have to get a transmitter that fits the proprietary sony hotshoe and get flashes that fit the sony proprietary hotshoe as well?
    Thanks for any help you can offer
  2. KmH
    Apr 9, 2009
    40,529
    5,540
    Iowa
  3. Nervine
    Nervine TPF Noob!
    Nov 21, 2011
    150
    6
    Adelaide, Australia
    I use pixel soldier wireless triggers/remote with my A77. They work like a charm, even when using different brand flash, ie: Sony HVL-F43AM, my old Minolta 5400HS and a Yongnuo I have all at the same time.
  4. tibrunner
    tibrunner TPF Noob!
    May 22, 2011
    162
    15
    Vancouver, Washington
    I use a standard Vivitar IR wireless shutter release for my a77, and a pair of pocket wizards.
    Both can easily be found on eBay or Amazon.
  5. jfrabat
    jfrabat No longer a newbie, moving up!
    Apr 15, 2012
    595
    58
    Panama, Central America
    I use Pixel Kings on my A77. Also work fine (I know Pixel says the Kings are not compatible with the A77, but the ONLY thing I cannot do with mine is set a flash on a receiver to act as a trigger for other flashes using the optical Sony propietary system; but I can use manual and TTL adjustments without issues). And range is pretty good too...
  6. Robin Usagani
    Robin Usagani Been spending a lot of time on here!
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    Have you considered shooting the interior when the sun is not bright? Maybe even shoot it at night + tripod + interior lights.
  7. jfrabat
    Apr 15, 2012
    595
    58
    Inside with flash there should be no issues; but for basketball games, you cannot be firing flashes off, so there it may be a bit of an issue...
  8. PWhite214
    PWhite214 No longer a newbie, moving up!
    Aug 6, 2011
    208
    53
    Houston, Texas USA
    I use an adapter to fit my ISO trigger to the Sony iISO hotshoe on my cameras. You can buy the iShoot PT-04 Trigger for the Sony iISO hot shoe and receivers for standard ISO hot shoe.
    Just search for 'iShoot' or, more general, 'Wireless flash trigger Sony'.
    Phil
  9. MetroRuss
    MetroRuss TPF Noob!
    Feb 15, 2013
    88
    5
    BC Canada
    Thank you for the replies. I have read conflicting info on dpreview. A fellow stated that I would not need a wireless trigger kit and that the yn560ii would work automatically off of my a57 flash activating. Is this true?
  10. jfrabat
    Apr 15, 2012
    595
    58
    I know you do not need a remote trigger to activate Sony flashes (you can use the Sony proprietary option), but I cannot speak for the yn560ii, as I do not own one...
  11. PWhite214
    Aug 6, 2011
    208
    53
    Houston, Texas USA
    The Yongnuo 460-II does have built in optical slave capability. As long as the ambient light does not overpower your 'trigger' flash, all should work fine. Yongnuo YN-460II YN460 II YN-460 II Flash Speedlight/Speedlite for Nikon | Yongnuo Store
    I bought radio triggers for the few times that optical would not work. I bought these from Amazon, Amazon.com: XCSource 16 Channel Wireless Radio Flash Trigger SET 1 Transmitter + 3 Receivers + 1 Sync Wire Cable for Canon 6D 7D 70D 60D 700D 650D 1100D 1000D 600D 50D 550D 500D 40D 30D 350D 400D 450D 30D 10D Rebel XS T5i T4i T3i T2i T1i T4 T3 Nikon , one transmitter and four receivers. A Yongnuo YN-H3 (about $8.00 on EBAY) adapts the transmitter to the iISO hot shoe on my Sony Cameras. There are some PIXEL TF-324, http://www.ebay.com/itm/TF-324-Hot-...=Camera_Flash_Accessories&hash=item3cbda90fc1, adapters for mounting my old Minolta flashes when necessary.
    Phil
  12. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,143
    2,943
    Chesterfield UK
    New A7 has a standard hotshoe so maybe from now on they could be standard
radio flash 5400hs
soldier wireless flash trigger sony sa
