water cooling a CPU and GPU
Discussion in 'Off Topic Chat' started by Skyeg, Jul 4, 2004.
  1. Skyeg
    Skyeg TPF Noob!
    Jan 25, 2004
    257
    Boston
    i was bored today so i decided im gonna water cool my computer and do some serious overclocking. i looked at the water cooling systems available and decided to build my own.
    heres what im thinking , tell me if you think i need to change part of it:
    im gonna take a copper heat sink, drill holes running parralel to the bottom of the heat sink very close to the bottom of the heatsink and put copper tubing through there so the water will be goign through the bottom of the heat sink. id do the same kinda thing for the GPU. and if i get really bored maybe solder some copertubing on the heatspreaders on my RAM. im gogi nto use plastic or rubber tubing to connect everything instead of trying to use all copper.
    the radiator will be a coil of copper tubeing in some type of enclosure with fans mouted on both ends (both pulling air in the same direction of course)
    the resevoir, pump and radiator will all be on the outside of the case my fulltower case is already full.
    good idea or bad idea?
  2. Scott WRG Editor
    Scott WRG Editor King of Smoothness
    Jun 21, 2004
    1,479
    16
    Haverhill, MA
    Interesting idea and in theory it should work. Make sure to seal everything up tightly before running power through the system. And take pictures, I'd like to see this.
  3. mrsid99
    mrsid99 TPF Supporters Supporting Member
    Mar 8, 2003
    2,964
    5
    Florida
    I've seen it done and it works to some extent but the bottleneck in heat dissipation is still going to be the processor/heatsink interface.
    Good luck and have fun!
  4. westman
    westman TPF Noob!
    May 7, 2004
    341
    are u gonna to do a massive overclock?!
  5. Skyeg
    Skyeg TPF Noob!
    Jan 25, 2004
    257
    Boston
    im gonna try to get a 2.8e to like 3.2 or 3.4 to start with.
  6. Skyeg
    Skyeg TPF Noob!
    Jan 25, 2004
    257
    Boston
    iv been looking for silicon tubing that will fit on a 1/8 barbed conector thingy.... i was going to use aquarium air line tubing but i dont like it. so far i havnt been able to find any silicon tubing anyone know where i could get some?
  7. westman
    westman TPF Noob!
    May 7, 2004
    341
    it doesnt need water cooling..
    using normal fan is alright
  8. Skyeg
    Skyeg TPF Noob!
    Jan 25, 2004
    257
    Boston
    for a 2.8e? prescotts run hot my runs at like 130 degrees F idle with included hsf...3.4 is just where i want to start, iv never oc'd a pentium 4 before so im taking it slow. ill probubly go past 3.4 ad id liek it to be significantly under 130 degrees idle especialy is its not oc'd.
  9. Darfion
    Darfion Soapbox guru...
    Jun 13, 2003
    1,498
    14
    Wigan, Lancashire
    You ever kissed a girl son?
    [chuckles]
  10. Skyeg
    Skyeg TPF Noob!
    Jan 25, 2004
    257
    Boston
    :lol: :lol:
    my girlfriend is in michigan so i have lots of free time
  11. Ant
    Ant TPF Noob!
    Jun 2, 2004
    438
    Luton. UK.
  12. Sharkbait
    Sharkbait TPF Noob!
    Nov 4, 2003
    2,403
    17
    Indianapolis, IN
    Oh my.
    LOL.
