Water Drops. (C&C welcome)
Discussion in 'General Gallery' started by John_05, Aug 25, 2008.
  1. John_05
    John_05 TPF Noob!
    Nov 26, 2005
    523
    4
    I've seen this done hundreds of times, but never tried it myself.
    I was bored one night, so I decided to try it.
    I took a glass bowl and filled it with cold water and placed it on top of my file cabinet (along with a towel to contain the mess).
    I set a 36" silver reflector above the bowl, tilted slightly towards the camera and flash. I hung a dragon towel I have on a piece of foam board behind the bowl for a colorful backdrop.
    With my camera and tripod set about 6 feet back, I focused on a coin I hung from a string in the general area I expected the drops to be. Once I got a good focus on the coin, I set the lens to manual focus.
    Rather than try to get uniform water drops without a dropper, I decided to drop small glass marbles into the water. After about 20 tries, this is the best one I managed to get.
    These are straight out of the camera, except for a slight sharpen after resizing.
    [​IMG]
    Here is a link to a slightly larger version.
    http://img.photobucket.com/albums/v348/john13901/d012afae.jpg
    I don't know if the EXIF is still intact, so I'll post that too.
    Sigma 70-300mm f4-5.6 DG with macro.
    f/13
    1/200
    190mm focal length
    metering mode - partial
    Any comments/critique or tips anyone has would be greatly appreciated.
  2. LaFoto
    Feb 1, 2004
    34,813
    817
    Lower Saxony, Germany
    Well done!
    Looks like one of my droplet photos that went into a small exhibition a couple of days ago! The surface looks just that tiny bit tilted, that's all, everything else is good.
    At 190mm, the Sigma had not gone into macro function as yet?
  3. John_05
    John_05 TPF Noob!
    Nov 26, 2005
    523
    4
    Thank you LaFoto.
    The edge of the bowl is slightly tilted. I hadn't noticed that. I thought it was just due to the shape of the bowl. I might try a reshoot when I get my bowl back. :lol:
    I wanted to use the macro function, but my apartment is a little too small. I couldn't get it focused in the limited space I have.
    For a lens that only cost $120.00USD brand new, I think it works pretty well.
    Thanks again for the compliments and for pointing that edge out. ;)
  4. Rachelsne
    Rachelsne TPF Noob!
    Jan 24, 2008
    1,137
    Yorktown, VA, USA
    oh thats great, very colourful, i keep meaning to try these with my sigma 70-300 apo dg macro too, maybe this week ill get round to it :)
  5. Resin42
    Resin42 TPF Noob!
    Jul 16, 2008
    376
    Glasgow, Scotland
    Very cool shot. I keep meaning to try these, I'll definitely use at least some of your set up technique.
  6. Chiller
    Chiller Mental case
    Dec 14, 2003
    9,736
    271
    F@cking Hell
    :thumbup::thumbup:
    Excellent. ​
  7. NateS
    NateS TPF Noob!
    Sep 27, 2007
    2,753
    40
    Missouri
    I've got the APO version as well and think I might try this as well.
    OP - I notice that you didn't need to use macro mode to get this shot. It also makes me wonder.....if you used macro mode at 200-300mm I bet you could focus close enough to get near full frame of the water droplet and possibly some cool reflections from the droplet. I may give this a shot....your shot is very nice by the way.
  8. PuppY_K1ck3R
    PuppY_K1ck3R TPF Noob!
    May 4, 2008
    178
    Ca. Bay area
    Very Very nice. And ur setup is simple and effective.
  9. John_05
    John_05 TPF Noob!
    Nov 26, 2005
    523
    4
    Thanks everyone.
    I actually have a picture of the set up I used. I was going to post it when I made the thread, but I was half awake and forgot to add it.
    [​IMG]
    When I try this again, I'd like to be able to catch more of the dragon reflected in the drop. I think moving the towel down a bit and using something else to get a slightly larger drop will help.
    I wanted to try that, but I couldn't move back far enough. I may try taking everything upstairs to the solarium so I have more than enough room to get just the drop in the frame.
    Thanks again to everyone for the comments.
  10. Resin42
    Resin42 TPF Noob!
    Jul 16, 2008
    376
    Glasgow, Scotland
    I meant to ask, why sharpen after resizing? Is this preferable or a matter of taste? (Genuine "don't know the answer" type question. :))
  11. MelodySoul
    MelodySoul TPF Noob!
    Jun 9, 2008
    308
    ON, Canada
    Very nice!
  12. John_05
    John_05 TPF Noob!
    Nov 26, 2005
    523
    4
    I normally don't sharpen after i resize, unless it loses a bit of detail. In this case, I think it looked a little bit softer, so I sharpened it, but only very slightly. I'm not sure if the percentage you size it down has an effect, but sometimes I notice sharpening isn't needed. I know when viewing the image in PSP X2 at an odd percentage, it looks softer. That may be why sometimes it's needed after a resize. I'm not sure.
