i like it. pretty cool with the snow. maybe a tighter crop on one side or another? im not too sure, but i like it!
Could you have gotten any closer? I would have shot from the bottom of the first cascade and probably composed vertical instead of horizontal.....if that makes sense.
It seems quite blurry and the snow/water is totally blown out.
I like the compositionin the second much better. Yeah photobucket will do that from what I have seen. I can tell it was overcast. Does your processing program have a good white balance converter for NEF? If it does you might try warming it up a bit to get rid of the flat light effect. Then I would play with the levels some after that. Just some suggestions you might play with to see what you can get. While I dont use them you might try Flickr as they seem to treat your photos better.
You don't mention shutter speed. The angel hair look suggests a fairly low speed. I'm guessing 1/30 or less. Did you use a tripod? SushiWarrior mentioned the blown out look of the water and snow. I like to shoot waterfalls and find that I need to under expose sometimes one or two stops from the meter just because water is so bright compared to the foliage around it.
Hi I'm a big fan of waterfalls and am slowly working to photograph all of the significant waterfalls in New England. Winter has slowed this down some though. I thought the shot was pretty good. You got the shutter speed down to give that veiled look to the falls. Unfortunately the bottom left is a little blown out. Underexposing just a little may have helped. I tend to underexpose many of my waterfall photos by narrowing the aperture as I don't want to change shutter speed. I could do the same with changing the ISO I guess. I'm still learning this stuff.
I would have shot this vertically and used the stream to lead the eye in or out of the photo but that is just my artistic preference. I liked how the photo came out though and would love to travel to this one. Where is it located?
i've always been a fan of slow shutter and waterfall/flowing water shots. i dunno why, but i like them.
this is one i took in Asheville, NC. not technically all that great, but I got the affect I was looking for and just like it for what it is.
not trying to threadjack!
