Website building software
Discussion in 'Digital Discussion & Q&A' started by Big Mike, Oct 3, 2007.
  1. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Can anyone recommend some website building software?
    I'm just trying to build something rather simple and I though I could get away with something free/shareware...but I haven't had much luck.
    I was thinking of FrontPage or Dreamweaver....but I'm not sure I want to spend that much on something I probably won't use very much.
  2. Chris of Arabia
    Chris of Arabia Herding cats since 1988... Supporting Member
    Mar 10, 2007
    7,825
    16
    The Magic Kingdom
    Take a look at Crimson Editor and Aptana.
    The former is pretty much just a (very) sophisticated form of Notepad, but one that recognises and colour codes HTML, PHP, Java, BASIC, ASP syntax etc. I use this all the time for stuff and it's open on my desktop now.
    Aptana does rather more and gets much nearer to what Dreamweaver does and will autocomplete HTML mark-up and JavaScript (which is it's real strength). If you check out the site, you'll find that future functionality will include the auto-complete & syntax checking for PHP and some other stuff too. It's an Open Source development, so it's free. I've not actually tried it yet, but it looks very promising and seems to have some very good write-ups.
  3. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    NVu is like Dreamweaver, but it's free. (and portable)
  4. Chris of Arabia
    Mar 10, 2007
    7,825
    16
    The Magic Kingdom
    Also try The Open Source Alternative for ideas. Type in the big name application you'd like to match and see what options it comes up with.
  5. gomexz
    gomexz TPF Noob!
    Sep 10, 2007
    55
    Indiana
    For the record I hate MS Front page. I had to use it when I did my High School's site. Currently for my site I am using Dream Weaver MX which would be my fav version. A friend of mine likes to use Kompozor. Which is an open source editor that is easy to use and free. You can find it here
    http://www.kompozer.net/
  6. Chris of Arabia
    Mar 10, 2007
    7,825
    16
    The Magic Kingdom
    Did you find anything you liked the look of Mike?
  7. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    I checked out Nvu...but the download didn't work. Kompozor is basically the same thing, so I tried that and it sucked.
    The other day, I downloaded one that I liked, called BlueVoda. I built a few pages, only then to find out that you can't publish anything without signing up for web hosting from them.
    Last night, I downloaded a trial version of a WYSIWYG editor from www.coffeecup.com and it's pretty good. I hear that their HTML editor is pretty good as well. They have many many sub programs for doing all sorts of things...and the problem is that you have to buy each separate application for what you want to. They do have a couple 'combo' deals where you can buy 8 or 9 of the programs in a bundle, for a decent price ($129). Although, I could probably find a version of Frontpage for close to that.
    I'm trying CoffeeCup for a while, and I'll decide if I want to purchase it. It certainly seems to be much better than any of the free ones that I tried.
  8. Keagle
    Keagle TPF Noob!
    Sep 2, 2007
    161
    Gloucestershire, England
    Please don't get Frontpage. As it's Microsoft, the Frontpage code will work perfectly in IE6/7, but not as well in Firefox/Opera.
  9. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Advice noted, thanks.
  10. gomexz
    gomexz TPF Noob!
    Sep 10, 2007
    55
    Indiana
    If u like BlueVoda. But if the program itself wont let u upload to your webserver. trying FTP'ing the webpages your self fromt he command prompt. It only takes a few simple commands.
  11. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    I tried pasting the code into another editor but it wasn't working for some reason...some of the things showed up but many didn't.
  12. gomexz
    gomexz TPF Noob!
    Sep 10, 2007
    55
    Indiana
    What i meant was when u save the pages you built you should be able to open it with I.E or Firefox. It should be just a basic .html file. U can upload the .html files from the command prompt your self with out even using the software. Im assuming you use windows. Lets say you saved your webpage files in "My Documents" you would go to start then RUN and in run you type cmd and press ok. a black box will appear. Then type cd "My Documents" once you are there. type ftp and then the IP address or hosting domain. and press enter it would prompt you for your username type it and press enter then type the password and enter. Then type put filename.html and enter. It will then upload the file for you. Which is what your software does for you. I hope that helped.
