What am I doing wrong?
Discussion in 'Photography Beginners' Forum' started by AndyH, Sep 9, 2010.
  1. AndyH
    AndyH TPF Noob!
    Sep 20, 2008
    51
    4
    Kingsport, TN
    It seems like I can't take a good pic! Is it me or the camera or both? lol! I can't ever seem to get good composition and when I do, the pic looks like crap. I took over 50 shots of my guitar and only a few turned out alright. I just could not get good lighting. I tried outside and inside, flash and no flash. I shot mostly on aperture priority. My camera will go f2.7 to f8. I shot mostly on f2.7. Any advice? Here's a few that turned out ok.
    [​IMG][​IMG]
    [​IMG]
    [​IMG]
  2. SrBiscuit
    SrBiscuit TPF Noob!
    Apr 22, 2008
    2,721
    44
    NH
    well youre using a P&S so the flash will be rather harsh...can you set up some constant lights?...even some cheapy work lamps from home depot?
    for some inspiration, maybe search 'guitar' on flickr and see if anything strikes your fancy.
  3. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    That is sort of like saying "I tried a D chord and a C chord...and I don't know why I don't sound like Clapton". ;)
    There is a whole lot more to lighting that just inside/outside, flash or not. And since photography literally means 'drawing with light'...it's pretty important.
    I'd suggest finding some shots on the internet that you do like, then trying to figure out what sort of lighting was used (we can help you there).
  4. tirediron
    Jul 8, 2005
    40,664
    12,309
    Victoria, BC
    You're not doing anything wrong; you just have more to learn. Good composition and lighting can take years of practice to get down pat. Technically this image is fine; it's sharp, the WB is good, but artistically it does leave something to be desired.
    First of all, what is your intended use for the images? That is, will they be for insurance records, artistic, advertising, or?? Each of them require a different approach. Spend some time on-line, Google "photographic composition" and simlar terms.
    As far as lighting goes, spend some time reading the Strobist.
  5. Christie Photo
    Christie Photo No longer a newbie, moving up!
    Jan 7, 2005
    7,042
    80
    Kankakee, IL
    psssst! Mike! Come here!
    Waddaya say we leave the guitar analogies alone? OK, Buddy?
  6. tirediron
    Jul 8, 2005
    40,664
    12,309
    Victoria, BC
    :lmao::lmao:
  7. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    :blushing:
    I knew that one was weak.
  8. lordfly
    lordfly TPF Noob!
    Feb 1, 2010
    114
    Monroe, Michigan
    The composition is good... the lighting is a little harsh on the first image. There's nothing wrong with what you're doing. :)
  9. AndyH
    AndyH TPF Noob!
    Sep 20, 2008
    51
    4
    Kingsport, TN
    Thanks for the advice! I'm just taking these pics for artistic purposes. I'll try to find some examples of what I'm trying to do and post them. Is aperture priority mode the best way to shoot these pics?
  10. Taylor510ce
    Taylor510ce TPF Noob!
    Jul 20, 2010
    702
    United States
    If the subject is stationary, I would use Aperture priority, but be sure you have a tripod or higher ISO if its low light. I think you should post a few of the "Not so good" pictures, that would help us tell you what was wrong. You are asking us what you are doing wrong, but showing us pictures that aren't really that bad at all. Doesn't make sense.
  11. AndyH
    AndyH TPF Noob!
    Sep 20, 2008
    51
    4
    Kingsport, TN
    ok here's a pic of what I'd like to do
    [​IMG]
    here's a pic I took earlier where I couldn't get it to look right. Looks like lots of noise and not sharp to me.
    [​IMG]
  12. enzodm
    enzodm No longer a newbie, moving up!
    Sep 5, 2010
    1,509
    118
    Italy
    At this resolution is difficult to tell about noise, however if you feel there is too much noise, perhaps you are shooting at high ISO. If so, lower ISO (possibly to the minimum if you like sharp images), which will mean you need longer exposure times, better reached with a tripod. It is also slightly underexposed.
    As I'm beginner (more or less), I can't tell nothing about lighting, however the first picture seems to have been taken in controlled light conditions, most likely no flash or no flash on camera at least. Look at 3D sense given by the curve on top left in the body, which has been evidentiated by light.
    However, the main difference between the two remains composition: choice of colors (cream and red) and position in the former picture will result better even with noise :D.
