If you want a real compact setup, you'll want to avoid the DSLRs. Either a more compact bridge camera or a mirrorless camera is the way I would go about it, if I were in your position. Things to keep in mind are to not worry too much about megapixels or super high focal lengths or zoom factors (unless you really like to shoot birds or wildlife). Also, if you go mirrorless, keep in mind you are buying into a system, and will want to have an idea of which lenses (and how much they cost ) are available for that system. Which camera(s) to get will depend on how you plan to use the camera(s), which only you know or will figure out. If you know how you plan to use the camera (as in what you plan to shoot, where, in what kind of light, etc.), please let us know so we can help narrow things down for you. Luckily, from what I've read, most newer cameras out these days are said to be very good overall. Hope that helps some.
There are compromises involved but you can certainly get great results from smaller mirrorless systems.
I use micro four thirds for much of my photography, having DSLR style bodies (Panasonic G5 and the older G1) & a smaller GF2 which doesn't have a built in viewfinder. The latest bodies will give have advantages over my kit - Olympus versions with in body stabilisation are certainly worth considering.
The GF2 with a pancake lens fitted can fit in a shirt pocket, with the kit lens a coat pocket is possible.
I prefer the handling of the other bodies having the camera to my eye feels more natural to me, in use they are fairly similar to my DSLR but take up less space & weigh significantly less. There are times when I prefer to use my DSLR - airshows, motorsports & birding in particular - this might be partly down to my AF lens options getting me closer with the DSLR, but the G5 gave respectable results at the touring cars last month when I didn't have space for the big guns.
IMO if space is an issue then mirrorless is the way to go. You still get the option of changing lenses to use something appropriate for the subject (a very important point for me) I'm sure there are others who find a good fixed lens 'compact camera' adequate for their needs.
If you are likely to be doing a lot of very low light photography, or work with very shallow DOF, you might find larger sensors become worth the extra bulk. There are mirrorless options in both APSC & FF sizes which will be more compact than the DSLRs with similar sensors, and the tiny Pentax Q series if even micro4/3 proves too big...
Awesome buddy, thanks for your response. ill have a look into them
i don't remember the gf2 w/ 20mm/1.7 or even 17/2.8 fitting in any of my shirt or pant pockets, but i don't have the camera handy to check on that...one of my more recent "rigs" is the fuji x-a1 w/ the 27mm/2.8 "pancake" which does remind me of my old gf2 and 20/1.7 combo but with noticeably better performance...The GF2 with a pancake lens fitted can fit in a shirt pocket, with the kit lens a coat pocket is possible.
I would ignore the Nikon 1 and Pentax Q systems for having an unnecessarily small sensor. Pentax Q has one because its a pretty old system; back then such small sensors gave a price advantage. But Nikon 1 has one only because Nikon didnt want to get into the Micro Four Thirds system. Their system has some advantages, but really unless you have very special demands its no good option.
As a former user of the Canon G11: nope. Really isnt. Unless they changed the camera size since, of course.I agree about mirrorless or bridge, but if size/weight are the big issue it's hard to beat some of the bridge cameras. For example the Canon G16 really is pocketable. The sensor is a little smaller than what you get on a mirrorless, but in good light/relatively low ISO you'll never notice the difference.
DSLRs have certain advantages:
- Reliable Autofocus even with action and lowlight
- Optical viewfinder; can be used indefinitely with no current useage (important for example for wildlife photography), no lag, especially also not in low light, no problems with artificial light (flickering problems), doesnt dazzle photographer by being too bright in low light etc
- Minimal current useage and thus very high number of images per battery possible; also no unnecessary heating of the image sensor
- Very reliable, well established product lines from Canon and Nikon; its quite safe to think these will persist
- Extreme abundance of quality lens offerings, with only few stinkers in between
- Large secondary producer market (Zeiss, Sigma, Tamron, etc)
- Very large and high quality used market especially for Nikon
- Abundance of additional equipment (flashes etc) from original and other producers
- All available systems have large sensors (minimum APS-C 24x16mm "Half format").
- For all systems theres also film cameras that can use the same lenses, if wanted.
- Pentax DSLRs unfortunately are much less well supported
- Sony (previously Minolta) "DSLRs" are now a weird alternative technology with EVF
And Mirrorless have too:
- Possibly smaller, simpler construction (but needs larger batteries)
- EVF quality is independent of sensor size, offers reliable 100% view of the final image composition, cannot blind the photographer when looking into the sun, offers review of the current white balance settings and other image shortcomings, and may offer many secondary functions such as focus peaking, life histogram etc that are not possible with optical viewfinders; sometimes also ability to flip the viewfinder up [Panasonic GX7].
- Short distance between lens and sensor allows simpler and higher quality wide angle lenses (but only if the company managed to solve the technological problems associated with steep angles from such lenses, as Leica did and as Sony managed with the A7s [but really only the A7s; the A7 and A7r cannot handle more extreme wide angles]).
- Larger AF area in the image, great support for manual focusing, contrast autofocus needs no calibration and is theoretically 100% reliable in hitting focus, phase autofocus like a DSLR is possible on sensor but the technology is not working as well as with DSLRs (speed problems, often doesnt work in low light except for Canons Dualpixels), and there is also Panasonics new advanced contast autofocus that relies on knowing the current lens and its characteristics in unsharp areas.
- All companies are young, the market has fast movements such as for example the Panasonic GH4 which leaves any DSLR in the dust when it comes to affordable high quality video (internal 4K video supported, 10 bit supported if external recorder is used)
Thus I really see no reason to get smaller than Micro Four Thirds. The Micro Four Thirds system has the best offer in lenses after the Canon and Nikon DSLRs offerings, and the camera bodies are impressively good as well, and most importantly the lenses are already VERY compact anyway.
If you really want even smaller, I recomment the Sony RX100 Mark II. I wont recomment the Mark III because the Mark III has a completely useless builtin EVF (that stalls when the camera is focusing) and while it offers more wide angle (a very good thing to have, no question) it also offers far less telephoto. The RX100 Mk2/3 offer the same sensor size as Nikon 1, but they have a high quality Sony sensor, while Nikon 1 technology requires special features of the inferior Aptina sensor.
There is ONE offer of Nikon thats worth a second look: the Nikon 1 AW1. This is a waterproof, shockproof, freezeproof camera for all the harsh environments. AFAIK theres only two lenses for that camera, though - a 28-75mm f3.5-5.6 zoom and a 27mm f2.8 prime. Well, as long as you want the lens and thus the whole system to be waterproof, shockproof, and freezeproof. AFAIK, for this class of camera, there is no model with higher image quality available.
