What Causes Pixelated Clouds?? Pic Included.
Discussion in 'Photography Beginners' Forum' started by Enem178, Jan 21, 2009.
  1. Enem178
    Enem178 TPF Noob!
    Jan 3, 2008
    268
    East Orange,NJ
    This doesn't happen to all my photo's but i've seen it a couple of times but only in day time shoots. This is straight out the camera with no pp. Thanks for the help.
    [​IMG]
  2. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    What is the shot info (exif)?
    Was this shot in JPEG or RAW?
    If JPEG, what resolution.quality?
  3. smithphoto
    smithphoto TPF Noob!
    Oct 20, 2008
    63
    Oklahoma, USA
    Man, It's been forever since I've been here. Any whoo...
    I've had this problem before and it always came from three things
    1. Low resolution images to begin with
    2. The conversion settings from RAW to JPG
    3. I've been told that some cameras can try to auto correct for sensor dust, this can also cause it apparently. I would recomend a good professional cleaning, this will be usefull reguardless of being an issue or not.
    Good luck with it none the less. Take this information with a grain of salt. I'm still a noob. Ha
  4. Jon0807
    Jon0807 TPF Noob!
    Nov 16, 2007
    357
    4
    San Francisco, CA
    looks like this was shot in lower resolution?
  5. Enem178
    Enem178 TPF Noob!
    Jan 3, 2008
    268
    East Orange,NJ
    1/125 f/10.0 iso 200 focal length 135mm,
    Shot in jpeg format and the quality was small.
  6. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    That's the problem right there. Low resolution.
  7. Enem178
    Enem178 TPF Noob!
    Jan 3, 2008
    268
    East Orange,NJ
    O ok, It might sound stupid but I though all I was changing was the size of the pix and not the quality. I've been shooting EVERYTHING in small since I bought the camera just because the pix are easier to email. So I should be shooting in the largest format always?
  8. Jaszek
    Jaszek No longer a newbie, moving up!
    Oct 7, 2008
    2,177
    29
    Brooklyn, NY
    Just shoot in large and than when you e-mail them you can always resize it.
  9. Enem178
    Enem178 TPF Noob!
    Jan 3, 2008
    268
    East Orange,NJ
    Will do, thanks..
  10. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    That cloud is not pixelated. You're just seeing color banding, which you will see every now and then especially when youre going from light to dark areas of the same color.
    Also "small" is not a quality setting. It is a resolution setting. Basic/Fine are "quality" settings.
  11. Enem178
    Enem178 TPF Noob!
    Jan 3, 2008
    268
    East Orange,NJ
    So shooting small/fine is the same quality as large/fine and if I dont plan on printing the image ill be good shooting small/fine?? If I go to print out a pic which has color banding, it wont show up in print will it?
  12. ANDS!
    Nov 14, 2006
    2,178
    Downtown
    You'll have more detail in the Large/Fine image, and some will qualify that as having superior "quality" than the Small/Fine image, but the compression algorithm used should be the same on both - just different resolutions.
    And, and I'm no expert, banding can be a mechincal condition (meaning on your display) and an image issue (meaning in the data of the file). I can see color banding on the above photo, but we both might have **** for monitors. Only way you can know is to do a print. Since banding is a TONAL issue, it should show up if you print in grayscale (and thus save your precious color ink).
apixulated clouds
pixelated clouds
what causes a camera to pixelate
what causes a photo to be pixelated
what causes ip camera to pixelate
what causes pictures to look pixelated
what causes pixelated images
what causes pixelation
what causes pixelation in a printed photograph?
what causes pixelation in photos
