What darkroom chemicals and kind of photographic paper do I need?
Discussion in 'Photography Beginners' Forum' started by acornrawr, Apr 28, 2011.
  1. acornrawr
    acornrawr TPF Noob!
    Apr 28, 2011
    6
    I'm looking to develop around 40 pictures cheaply, but I don't know what kind of photographic paper or developer chemicals that I need.
    For my project, I want to allow light to shine on certain parts of the paper (by covering up part of it when I turn on a light) and then develop it to see which parts of the paper were exposed.
    Can anyone tell me the cheapest darkroom chemicals and kind of photographic paper I should buy?
    Thanks!
  2. CCericola
    CCericola Been spending a lot of time on here!
    Jan 5, 2011
    1,921
    566
    Washington
    Are you going to print in color or black&white?
  3. acornrawr
    acornrawr TPF Noob!
    Apr 28, 2011
    6
    color or black and white? Which ever is cheaper. I just need the exposed parts of my paper to be significantly different than the unexposed parts.
  4. CCericola
    Jan 5, 2011
    1,921
    566
    Washington
    Black and white is usually cheaper. What kind of enlarger you have?
  5. acornrawr
    acornrawr TPF Noob!
    Apr 28, 2011
    6
    I was going to cover up parts of the photographic paper with cardboard pieces. Then shine light on it briefly. Then develop the paper to end up with the "shadow" of the cardboard pieces on the paper.
    My project doesn't need very high resolution images. My project just needs the papers to have low res images (like large letters) after developing and needs the low res images to be not be legible if the paper is exposed to additional light before developing. I really can't find a cheap way to do this.
  6. MattxMosh
    MattxMosh TPF Noob!
    Apr 26, 2009
    282
    Merrimac(k) Valley, Ma
    Make 4x5 pin hole camera from old shoe box and used 4x5 holder, use paper as film, drag dark slide an inch every second or so depending on size of pinhole, buy cheap developer, success.
    That will be $100.
  7. CCericola
    Jan 5, 2011
    1,921
    566
    Washington
    Oops! You gave him the info before the check cleared! :)
  8. acornrawr
    acornrawr TPF Noob!
    Apr 28, 2011
    6
    Why would what I described not work? (Covering up parts of paper with cardboard pieces.) It would expose only the parts that I want exposed.
    Where can I buy cheap developer, fixer, paper and whatever else I need? The cheapest I can find to do this is ~$20 for the smallest amount of developer and fixer powder they sell on Amazon.com (1 liter each), then ~$20 for the smallest pack of photography paper they sell, and use water for stop bath.
  9. acornrawr
    acornrawr TPF Noob!
    Apr 28, 2011
    6
  10. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    you will also need stop bath. You might check out Freestyle for their brand of papers, as they may be cheaper.
    Are you contact printing this project? Or, enlarging ?
  11. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
  12. acornrawr
    acornrawr TPF Noob!
    Apr 28, 2011
    6
    what do you mean when you say "if you use too bright of light your exposures will be too short"?
    does photographic paper need a low intensity exposure over a long period of time? would it work if I simply covered up the parts of the photographic paper I wish to be unexposed and then turned normal room lights on for a second?
what chemicals to use in the darkroom and what not to use
why do you have to use photograph paper in a darkroom
