What does this mean?
Discussion in 'Photography Beginners' Forum' started by daisy, May 28, 2007.
  1. daisy
    daisy TPF Noob!
    Apr 23, 2007
    18
    If someone says:
    your {insert mm} has barrel distortion
    What does that mean exactly?
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Barrel Distortion
    Some focal lengths are more prone to different types of distortion. Usually, better quality lenses have less distortion.
  3. The_Traveler
    The_Traveler Completely Counter-dependent Supporting Member
    Dec 11, 2006
    18,339
    7,570
    Mid-Atlantic US
  4. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    It means they are probably a soulless automatron more concerned with gear, process, and rows of technical numbers than art. Sure they can spot barrel distortion at 20 feet, but ask them what makes a photograph beautiful, and they are stumped. Don't worry about it; you can see barrel distortion just as well as they, but if it didn't bother you before you knew what it was called, it shouldn't bother you now. ;)
    Depending on what you are doing, lens distortion may or may not be an issue. The idea that there is such a beast as a distortionless lens is silly though. Look at a photo of someone taken with the greatest lenses ever designed; do you think in real life that they are 2 inches tall and flat? ;)
