What filter should I use...
Discussion in 'Beyond the Basics' started by awolffh, Nov 3, 2009.
  1. awolffh
    awolffh TPF Noob!
    Nov 3, 2009
    5
    bermuda
    Hi there, I am looking for some suggestions. I have to take photos of some gift baskets at my work, and the ones I have taken so far are good except for the glare from the cellophane wrap that the baskets are covered in. Can anyone recommend which filters may help to reduce this glare and produce a better photo? Would it just be any circular polarized filter or is that entirely wrong? I have never taken photos of anything like this before so any advice is appreciated. Thanks!
  2. GeneralBenson
    GeneralBenson TPF Noob!
    Mar 28, 2008
    1,106
    18
    Boulder, CO
    Sounds like a job for a polarizing filter.
  3. peterbj7
    peterbj7 TPF Noob!
    Jan 21, 2008
    118
    Oxford UK and Belize
    Unless you can remove the cellophane for the photos and replace it afterwards. A circular polariser will help but won't remove the problem completely. Try very diffuse and indirect lighting.
  4. awolffh
    awolffh TPF Noob!
    Nov 3, 2009
    5
    bermuda
    Thanks for the replies... I can't remove the cellophane because it is the whole 'gift basket' idea we want to sell so we want photos of them all wrapped up with the cellophane and bow looking pretty. I will try a circular polarizer and also the lighting tips and hope for the best. Thanks again guys, I appreciate it. Any specific circular polarizer or are all brands the same? I have not ever looked at them so I am not sure what choices are out there.
  5. peterbj7
    peterbj7 TPF Noob!
    Jan 21, 2008
    118
    Depending on the lens you're using you may find you get some vignetting, which should be reduced by using a very thin filter. That will also probably be a high quality filter. Although it isn't an infallible rule, if the filter is cheap the results probably will be as well.
  6. awolffh
    awolffh TPF Noob!
    Nov 3, 2009
    5
    bermuda
    The camera is a Nikon D40 DSLR. The lens is (and this is from its manual, I don't know which info is important, sorry I am just a beginner! ):
    AF-S DX VR Zoom-Nikkor
    55-200mm f/4-5.6G IF-ED
    Thanks again for your help, the info is appreciated. I will look for a good quality thin filter
  7. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    You shouldn't have to worry about a thin filter for that lens.
  8. awolffh
    awolffh TPF Noob!
    Nov 3, 2009
    5
    bermuda
    Do you mean that I should not use a filter at all or just not a thin one? Without a filter at all the glare is quite evident in the photos
  9. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    203
    Canada
    Vignetting is NOT going to be a problem with your lens, so any circular polarizer will work fine, and will help to reduce the glare.
    skieur
  10. awolffh
    awolffh TPF Noob!
    Nov 3, 2009
    5
    bermuda
    Thank you so much everyone who replied, off to get a filter. I appreciate your help.
