What filters for my application?
Discussion in 'Photography Beginners' Forum' started by KooK, Jan 30, 2009.
  1. KooK
    KooK TPF Noob!
    Jan 30, 2009
    47
    Bouncing around
    I'm not about to sit here and tell people I don't have a budget for filters, but in the same respect, I'm not going to ask for the cheapest one. I have NO idea what I'm talking about when it comes to filters, I don't own any, I don't really even know where to start researching them without worry that the source is bias in any way. I'm looking to stay around or below $100 a filter and I'm wondering what 2-3 filters you guys would recommend for somebody just starting out. My equipment is listed in my sig, I'm trying to stay away from using a flash until I learn the logistics of the camera and how to use it a little better.
    From what I've at least been researching, I'm thinking of starting with a UV Filter, a ND Filter, and maybe a Polarizing filter of some sort. I will still research what anybody points me to, but I want to see if these are good starters, and what brand and spec to look for.
    I appreciate this a bunch, thanks in advance!
    P.S.
    I mostly do a lot of outdoors and moving shots, a close second will be things like cars that are just sitting there either out in the light, in a parking garage, it really varies.
    Edit: I'm sorry, I didn't see there was a separate sub-section for equipment, could a moderator or admin please move this? Thanks.
  2. sultan
    sultan TPF Noob!
    Mar 5, 2008
    302
    Mississauga, Ontario, Canada
    Yeah, I think a UV and Polarizing filter would be a good place to start. You should have a good quality UV filter on all your lenses all the time to protect them from damage. A polarizer would also be a good idea. I recommend Hoya filters if you want something that is both affordable and good quality. Tiffen UV filters are good if you want a simple and rugged filter. B+W filters are of very good quality (German made), but are expensive. But then having something that says "Made in Germany" makes me feel good inside, because I can be confident it won't reduce the lens's optical quality.
    I'm not sure about the ND - what are you planning on using it for? Do you want to do extra-long exposures? Get one if you thing you'll need one. Also consider getting 2 polarizers instead of an ND set. When you put 2 polarizers together, one in front of another, you get a variable ND filter. Simply rotate the polarizer to adjust opacity.
    P.S. Make sure you get a "circular polarizer" if you shoot digital. Regular polarizers sometimes don't work well on digital cameras.
  3. Mgw189
    Mgw189 TPF Noob!
    Dec 31, 2008
    838
    Binghamton, NY
    Circular Polarizer
    Graduate ND filter
    UV filter
  4. kn4ds
    kn4ds TPF Noob!
    Dec 24, 2008
    115
    Perry, GA
    Investigate the Cokin Creative Filter system... the A series allows you to "stack" up to 3 filters in front of the lens.
    One of the beauties of this system is that when you move to a new camera, if the lens barrel is a different size, you only need to get a new adapter ring, as I just did for the Canon Rebel XS (58mm) after years of using it with my Minolta (52mm).
    $8, and I can use all my Cokin filters with the new camera... sure beats having to buy all new filters.
    That said, I do recommend the UV (mostly for protection of the front lens element) and a good circular polarizing filter in your lens size.
    But Cokin has a WIDE variety of creative filters, including basics like graduated neutral density (have to be careful to re-orient them on an autofocus lens!), various colors, star filters, etc, etc.
    I've been a fan of the Cokin filters for over 20 years.
    Just my 2 cents' worth.
