What fluid for cleaning flatbed scanner glass
Discussion in 'Photography Equipment & Products' started by epp_b, Nov 24, 2008.
  1. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    I've taken apart my flatbed scanner so that I can access both sides of the glass for cleaning. I have a microfibre cloth ready. What fluid should I use to spray onto the cloth for cleaning the glass? I understand that Windex is not to be used.
    I have a bottle of Nexxtech Anti-Static Cleaning Gel (it's not really gel, it's just as fluid as water) that says it's for Plasma and LCD screens. The fluid is simply a bit of Sodium Lauryl Sulfate in water. Is this OK to clean the scanner glass with?
    I just tested it by cleaning a cheap magnifying glass I have. There appear to be no streaks or spots.
  2. tasman
    tasman TPF Noob!
    May 7, 2006
    468
    Edmonton, Alberta, Canada
    Should work good, as long as there are no streaks. I dont know why you cant use windex on it, It is glass not plastic. I also use a cleaner that I get for cleaning eye glasses.
  3. epp_b
    Aug 22, 2008
    2,135
    12
    Apparently Windex can leave a nasty blue hue on the glass.
  4. tasman
    tasman TPF Noob!
    May 7, 2006
    468
    Never heard of that before.
