What happens when shooting iso100 film at iso50, or iso25?
Discussion in 'Photography Beginners' Forum' started by Treymac, Oct 14, 2009.
  1. Treymac
    Treymac TPF Noob!
    May 19, 2007
    168
    Vancouver, BC
    Hey guys. What happens when shooting iso100 film at iso50, or iso25? Does it allow you to keep your shutter open longer? If it does, how much longer does it give your shutter?
  2. Plato
    Plato TPF Noob!
    Jul 11, 2009
    1,058
    United States of America
    ISO 50 - twice as long. Photo too light.
    ISO 25 - four times as long. Photo much too light.
    Find a book on basic photography.
  3. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    You under or over expose when you set your ISO dial to something other than your film ISO. If you have ISO 100 film and set it ISO 200, the meter will underexpose by one stop. If you have ISO 100 film and set to 50, the meter will overexpose by one stop. If you have ISO 100 film and set to 25, the meter will overexpose by two stops.
    And so on and so forth...
  4. molested_cow
    molested_cow No longer a newbie, moving up!
    Jul 3, 2004
    3,645
    469
    Here N There
    Not sure if I am right, but if you set your camera to iso50 when using a 100 film in Aperture priority mode, your shutter speed needs to be 1/2x. At ISO25, it should be 1/2X1/2=1/4 times.
    The reason is your camera thinks that you need more light, therefore you actually need to underexpose according to what your camera's light meter is telling you.
  5. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    the feature to change your film speed on Film camera's is basically to help the Inbuilt light meter to guess a closer to accurate measurement.
  6. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    well, if you want a little light reading... you can check this out
    ISO-WIKI
  7. chris
    chris No longer a newbie, moving up!
    Jun 20, 2003
    281
    28
    Scotland
    Don't forget that if you reduce the film speed then you will have to reduce the development time to compensate; this is easily done if you process the film yourself or send it to a professional laboratory, a in-store auto lab will probably not be able to adjust the development time and you will then just end up with over exposed negatives. Also, you need to expose the whole film at the lower film speed, not just odd frames.
    The easiest way to get long exposures if just stopping the lens down is not enough is to use a neutral density filter.
shooting film at different speed
shooting iso 50 film at 100 iso
shooting iso200film at iso 100
