What is a Olympus 14-45mm 3.5-5.6 lens best at?
Discussion in 'Olympus Cameras' started by photowarrior15, Dec 18, 2015.
  1. photowarrior15
    photowarrior15 TPF Noob!
    Aug 30, 2015
    4
    Just picked this lens up from a friend of mine. He switched to Nikon and really didnt use his Olym equipment much, so I was wondering what is it best for, Landscape, portrait etc.?
  2. AKUK
    AKUK No longer a newbie, moving up!
    Feb 1, 2015
    344
    266
    Kent, United Kingdom
    Traditionally wide angle lenses are used for landscape photography. With the 4/3rds sensors you get a x2 crop, so the field of view is like a 28-90mm lens on a full frame camera. You can use the lens for any type of photography you want. I've used wide angle lenses for portraits and super-telephoto lenses for landscape shots. With that being said, the angle of view won't give the most flattering compression on the face for close up portraits but, for environmental ones, it will be fine.
    Obviously it won't be the best for wildlife shots because it lacks the pulling power of a 300mm+ lens. You'd have to get close to your subjects to achieve the same. Not impossible but certainly a lot more difficult and potentially dangerous depending on the subject matter. Just don't fall into the trap of defining lens use by the focal length, as you only limit your creativity.
  3. photowarrior15
    Aug 30, 2015
    4
    Ok, thanks. Another quick question. I know to put a 4/3 lens on a micro 4/3 body i need a adapter, but can a micro 4/3 lens go on a 4/3 Body?
  4. AKUK
    Feb 1, 2015
    344
    266
    I'll have to defer that to someone with more knowledge of the Micro 4/3 system. I know that the sensor distances are vastly different (20mm if I remember rightly), which is why you require the adapter for the 4/3 on the M4/3 bodies. Other than that, I'm at a loss.
  5. jaomul
    jaomul Been spending a lot of time on here!
    Feb 4, 2011
    5,550
    1,474
    Cork Ireland
    I'd say that lens is probably good for taking photos ;). It's not very good as a hammer.
    • Funny Funny x 1
  6. jcdeboever
    jcdeboever TPF Supporters Supporting Member
    Sep 5, 2015
    14,406
    7,832
    Michigan
    You can get some nice, older glass pretty cheap, all you need is the proper adapter. Google it, you will see. I know someone with an Olympus pen and he uses Canon FD lens on it with a simple mount adapter if I am not mistaken.
  7. xenskhe
    xenskhe No longer a newbie, moving up!
    Feb 18, 2016
    311
    58
    No, it's a longer registration distance between the lens mount and the sensor. If you were to somehow adapt the lens, it would focus only very close up.
  8. pixmedic
    pixmedic The Mustached Moderator Staff Member Supporting Member
    Jun 7, 2012
    14,246
    6,664
    Central Florida
    when I had my E-PL5, i picked up a mint Konica 57mm f/1.2 lens at the flea market sitting on an old minolta camera for $20.
    ordered a cheap adapter for it on ebay and stuck it on the Oly. you can get an adapter for pretty much any lens for m4/3.
    [​IMG]Oly E-PL5 with Konica AR 57mm f/1.2 by pixmedic, on Flickr
    • Like Like x 1
  9. mctb
    mctb TPF Noob!
    Apr 28, 2016
    40
    12
    It is a good, cheap, walk around zoom as long as the lighting is okay. The slower app means longer shutter times. I use mostly primes on my EM10 but when I take my daughter to the park and she is running around, a zoom is a good thing to have. And to be honest, it is not a bad one.
    [​IMG]JMHP1599 by Jarrod Hills, on Flickr
    This was taken with it. Feel free to follow the link and zoom in. It is a very competent lens.
