What is causing this blue spot?
Discussion in 'Photographic Discussions' started by RMThompson, Feb 2, 2009.
  1. RMThompson
    RMThompson the TPF moderators rock my world!
    Nov 12, 2006
    1,888
    11
    ARGH!
    In my last few sessions, I am having this blue spot glare that I cannot seem to beat. It's not the end of the world, and usually very editable, but STILL I'd like to get rid of it.
    See an example in the photo below and let me know if you know a way to eliminate it.
    The set up was D50, wirelessly triggering two lights with umbrellas in front of the model, and lights behind to blow out the back (which weren't configured by the studio owner right... :( )
    Anyone that can offer advice, let me know.
    [​IMG]
  2. Captain IK
    Captain IK TPF Noob!
    Dec 5, 2008
    630
    Windsor, ON. Canada
    Does the blue spot appear in the same frame location every time? If so, I would think it is something to do with the camera sensor
  3. RMThompson
    Nov 12, 2006
    1,888
    11
    No no, it's definetly something with the lighting. My first guess is that its the light being so bring it's reflect off the wall behind her, and then back into my lens.
  4. Captain IK
    Dec 5, 2008
    630
    Windsor, ON. Canada
    Oh okay Sorry I misunderstood.
    Maybe try a few test shots, each one eliminating one light. That way you can at least find out which source is the problem.
    Just a thought
  5. craig
    craig TPF Noob!
    Oct 30, 2003
    5,600
    21
    Hermosa Beach, CA U.S.A
    Lens flare. The expensive large lens hood could eliminate it. Also removing any filters helps. If you are shooting with a tripod you can use black cards to flag the lens. More then likely you will have to flag the strobes with black cards.
    Love & Bass
  6. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    Yep. Lens flare.
    But a lens hood may not cure it.
    What you need to do is to find it's source. Move around with a piece of black card and watch the effect on the lens. Maybe take some test shots.
    When you find the source use a flag to block it or move the lights a bit.
    BTW this Forum is for non-technical matters. ;)
  7. KvnO
    KvnO TPF Noob!
    Jan 12, 2009
    208
    Michigan
    Are you sure it has nothing to do with her shorts?
  8. RMThompson
    Nov 12, 2006
    1,888
    11
    oops. Your right, wrong forum.
    Can someone describe the black card a little bit more? I am wondering if I was less straight on, it might help. I think from angles worked best.
  9. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,143
    2,943
    Chesterfield UK
    You have light coming in from the side so you have to place a board between you and the flash or step back a bit, i have used my hand before
  10. Mike_E
    Jan 26, 2007
    5,327
    266
  11. Ejazzle
    Ejazzle TPF Noob!
    May 3, 2008
    653
    Jupiter/ Tequesta FL
    phone number?
  12. craig
    craig TPF Noob!
    Oct 30, 2003
    5,600
    21
    Basically if you are using umbrellas you have light flying all over the place. Soft boxes are a little easier to deal with because the sides are black. The black flags would be placed as illustrated. Depending on the size of the flags and the position of your lights you will move them around so that you are never getting stray light. Let me know if that makes sense.
    Love & Bass
    [​IMG]
