What is the best choice for size of picture?
Discussion in 'Photography Beginners' Forum' started by photo_passion, Feb 17, 2010.
  1. photo_passion
    photo_passion TPF Noob!
    Jan 1, 2010
    17
    So I have a choice of Small, Medium and Large size of pictures in the cam configuration. By SIZE I mean dimensions of side1 * side2.
    If I choose large, in the end they will have to fit in a screen much smaller than they really are...
    So if my goal is to have the best quality possible when published in the web or in a computer viewer what should I choose for original pic size?
    I suspect that if I should choose large, then I will be able to crop with less loss of quality than if the pic was small already. Am I correct?
    If I choose small size, and the image will be put in the screen without being forced to fit too much into a smaller area do I gain quality?
    Thanks in advance,
  2. IgsEMT
    IgsEMT No longer a newbie, moving up!
    Jul 27, 2009
    2,694
    48
    NYC
    yep
    shoot largest possible and shrink it in processing,
  3. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    If you are only going to show the images on the web or a computer screen, then you probably don't need the large size...however, using the large size gives you more options. More info for cropping etc. And if you ever want to print a photo, you'll be glad to have it in large size.
  4. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    I don't think I've ever seen that before. I've seen a variable quality setting like normal, fine, super or whatever which makes a smaller to larger file size, but not one which physically makes the image dimensions smaller. What's the purpose?
    Memory cards are practically free now, shoot in the best quality possible and then edit it to what you need.
