What is the professional focal range for pictures generally?
Discussion in 'Photography Beginners' Forum' started by Treymac, Feb 25, 2008.
  1. Treymac
    Treymac TPF Noob!
    May 19, 2007
    168
    Vancouver, BC
    Hey guys. I've always liked shooting at around 18mm because I like to get lots of things in. But my question is, professionally, should I not shoot at such a low range? Is it more professional to shoot things at around 50mm?
    I suppose that I do shoot at 50mm sometimes, but that's almost always only in doors. Outside shots I like 18mm, although if I need to zoom I'll go higher.
  2. Jon0807
    Jon0807 TPF Noob!
    Nov 16, 2007
    357
    4
    San Francisco, CA
    I think there is no "proffessional range" because there are so many different styles of photography and every situation will be different. Sometimes you may need to zoom in and sometimes you may need to shoot wide. What counts is the end result which includes composition, technique, style and a personality. Focal range is just part of what it takes to accomplish these things. I doubt any professional will tell you they only shoot with a single focal range unless they specialize in one particular style such as macro
  3. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    There is no 'professional' focal length. Shoot at what you want to or like.
    There are other factors though. For example, I wouldn't call your lenses (18-55 & 75-300) 'professional' quality. The 18-55mm for example, probably isn't at it's best at 18mm and especially not at it's widest aperture (F3.5-5.6).
    If you want to have more 'professional' looking images...you might want to consider a more professional lens. The 17-55mm F2.8 IS, lens for example, is the same range as your 18-55 lens...but it costs about 10 times more. ($1,000).
    Really, it isn't the equipment you use or the focal length that you use...that makes you professional.
  4. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    8mm to 1200mm and everywhere in between.
