Through-The-Lens
Modern cameras with E-TTL (Electronic TTL, I think)...will usually fire a pre-flash, the camera measures this test flash and use it to calculate how much flash output to use for the actual exposure. This all happens very fast, you might not even have noticed that the flash went off twice.
A-TTL was the older Canon version wasn't it? Probably Automatic TTL :scratch:So what's A-TTL. I've always wondered how they differ.
Do they call that TTL...Since is isn't using any of the light that is actually coming 'through the lens' of the camera? I just see those called 'Auto' or 'Auto Thyristor'.But, TTL auto is where the flash uses a built in sensor to shut itself off when it has received back enough light to properly expose for a set aperture
