What kind of light bulbs should I use?
Discussion in 'Photography Beginners' Forum' started by Starlite, Oct 27, 2006.
  1. Starlite
    Starlite TPF Noob!
    Oct 25, 2006
    63
    So Cal
    Ok so my light set arrived today, and I'm happy about that.... but it came with some generic looking Phillips light bulbs, of 100 watts.
    I don't know what kind of light bulbs I need, nor how may watts.
    Can someone help me out on this?
    I've found a couple things on Ebay that looked interesting:
    http://cgi.ebay.com/ws/eBayISAPI.dl...MEWA:IT&viewitem=&item=110044359321&rd=1&rd=1
    http://cgi.ebay.com/ws/eBayISAPI.dl...MEWA:IT&viewitem=&item=110044861094&rd=1&rd=1
    Can anyone educate me a little bit?
    Like on the first one, it says the bulb generates 120 watts of light at only 30 watts power, which generates less heat... that sounds great, but I don't know how many watts I should be using, per light bulb. I tried the 100 watt bulbs that came with my package, and when I tried using it with the silver umbrella, not very much light was being reflected back.
    The soft white translucent umbrella, seemed to work better with that bulb.
    What are these kind of bulbs CALLED anyways? The ones that are generating more light wattage then the power wattage they use?
    Can I buy these kind of bulbs at a local store? Or are these specialized or professional type bulbs, that I can only find in a professional store? (i live in LA, by the way)
    thanks very much for reading this :hug::
  2. Starlite
    Starlite TPF Noob!
    Oct 25, 2006
    63
    So Cal
  3. Starlite
    Starlite TPF Noob!
    Oct 25, 2006
    63
    So Cal
  4. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    Check the literature which came with your gear to find out the maximum recommended wattage.
    Then check any of the major camera stores for ordinary incandescent bulbs of that wattage. They come in wattages up to 500. Pricing is reasonable.
    If you're using a digital camera, don't forget to make the necessary light source adjustment.
  5. W.Smith
    W.Smith TPF Noob!
    Oct 11, 2006
    440
    Wouldn't halogen lights be an alternative? Doesn't generate as much heat as tungsten does in the proper fittings. And six times the power output, from the same power consumption, as I understand it. Continuous too.
    WB can be custom measured and set. Or you can use the preset WB for fluorescent light many cameras have. If you shoot RAW you'll have even wider latitude to adjust later.
    Any of you ever used halogen light in a studio?
  6. Torus34
    Jan 26, 2006
    2,117
    37
    Halogen sounds like a good idea to explore. I'm afraid I'm a bit 'old school' in the area of studio lighting. I tend to rely on those things I know well -- sometimes to the exclusion of trying something newer and better.
  7. Starlite
    Starlite TPF Noob!
    Oct 25, 2006
    63
    So Cal
    Check the literature that came with my digital camera? Are there recommendations for specific wattage lights for different cameras?
    I AM using a digital camera (HP Gateway 5 megapixel – until I upgrade), but what are the “necessary light source adjustments”?
    “Halogen” light bulbs? Any links so that I can check them out? How are these better/different then fluorescent?
    No comments/replies regarding the bulbs I posted above? I was hoping to get some feedback from those who are experienced, about those light bulbs, and what bulbs are good for portrait shots.
  8. Starlite
    Starlite TPF Noob!
    Oct 25, 2006
    63
    So Cal
    I did some further looking today, and I am noticing that bulbs above 125-150 watts, really jump up in price.
    Can anyone tell me how many watts I should shoot for, and/or suggest the best places to shop for light bulbs?
  9. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    What types of things are you going to be shooting? With continuous output lighting, you often end up with longish shutter speeds. The output is no where near the intensity of flash. If you are shooting still lifes, it's ok. Mount the camera on a tripod and go for it. For shooting portraits handholding at 1/30 and slower is not recommended. Your models may not be able to hold still enough either.
  10. blooper
    blooper TPF Noob!
    Sep 7, 2006
    72
    for my studio shots, i use 500watt 120volt flood bulbs. they light my tiny room extraordinarily well. i also pop on a couple umbrellas to diffuse the light and walla(sp)! i shoot live models tho, so the heat that is generated from these bulbs can be irratating.
    if youre shooting products, i think 250watt bulbs will be enough. since you dont have to worrying about singeing the hairs off their skin by moving the lamps closer, you can afford to locate the lamps close with lower wattage.
    but if you are shooting live models, consider the temperatures.
  11. Starlite
    Starlite TPF Noob!
    Oct 25, 2006
    63
    So Cal
    I'm looking to shoot live models - portrait type photos.
    Do they make "cool" lights that have enough wattage that won't be as hot? Is two lights of 250 watts enough, or do I need to think about 500 watts each?
    Where do you suggest I shop for bulbs?
    thx
  12. Starlite
    Starlite TPF Noob!
    Oct 25, 2006
    63
    So Cal
    May I ask you to elaborate just a little? What do you mean I will often "end up" with longish shutter speeds? Because the continuous lights don't have the output intensity of a flash? How much wattage does a flash give off? Can I come close?
    I'm puzzled tho, why I would "end up" with longish shutter speeds.. I mean, would I be setting the shutter speed myself, or would this be from the camera setting it automatically?
    I know I need to experiment/work more, to learn this, but if you could help out with any elaboration..........
    :hail:
best bulb to use in umbrella lights
best bulbs for photography
best bulbs for photography lighting
best light bulb wattage for photography
best wattage for indoor photography
what kind of light bulb for photography
what kind of light bulbs for photography
what kind of light bulbs should i use for photography
what kind of lightbulb to use for photography
what light bulbs to use in photography
