What lens should I use with my Nikon D300
Discussion in 'Photography Equipment & Products' started by lookhartphotography, Jan 17, 2009.
  1. lookhartphotography
    lookhartphotography TPF Noob!
    Jan 17, 2009
    7
    I do mostly weddings and engagements. After reading reviews (and many hours of frustration with the camera) I found out it is because of my lens I have now. I have a tamron 28-200 and a sigma 18-200. I have had wonderful pictures from these lenses on my nikon d50 but not with the D300. So.... what lenses should I invest in for my D300? When I shoot I do lots of quick and candid shots. So please help this frustrated photographer who is learning. I want to use my D300 so much but everything is always so dark! Thanks! Happy shooting!
  2. Pure
    Pure TPF Noob!
    Oct 22, 2008
    420
    The 70-200mm f2.8 because.....f/2.8, quiet [for churches/ceremony], VR [for low light], and quality of glass.
    And then a wide angle?
  3. lookhartphotography
    Jan 17, 2009
    7
    thank you for your help!
  4. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    You'll want a wide-to-mid range like the 17-55 / 2.8 as well.
  5. Captain IK
    Captain IK TPF Noob!
    Dec 5, 2008
    630
    Windsor, ON. Canada
    Does anyone know why there is a lens issue between these two cameras?
  6. Mike_E
    Jan 26, 2007
    5,327
    266
    There shouldn't be.
    The OP might make sure that the EXP COMP is zeroed and that the meter selector is not on spot.
    As to the other, I have a 28-80mm f/2.8 that I'm fond of. Some like a shorter range but I find that standing back and using a little longer range keeps the faces from being noticeably distorted. I would rather stitch photos together and resize than have to try and repair a nose that's 1 1/2 times as long as it should be. (shooting in full manual with a set WB helps in doing this as well)
    $0.02
