what macro lens?
Discussion in 'Landscape & Cityscape' started by RedDevilUK, Apr 9, 2007.
  1. RedDevilUK
    RedDevilUK TPF Noob!
    Apr 4, 2007
    321
    Rochdale UK (N. Manchester)
    im a newbie and want to do macro work, what lens or extension lens would you recommend? i am using a D80 with the AF-S Nikkor 18-70mm at the moment
    [​IMG]
    [​IMG]
    [​IMG]
    Thats the best i think i can get with this lens :( i was thinking of getting some extension tubes...
  2. lostprophet
    lostprophet No longer a newbie, moving up!
    Feb 10, 2006
    11,770
    109
    if you can afford it the Nikon 105mm VR is stunning and the VR really helps when you haven't got a tripod with you.
    Sigma are very good also, the 105mm and the 150mm are cheaper than the Nikon but are still very sharp
  3. airgunr
    airgunr TPF Noob!
    Mar 21, 2004
    846
    4
    Delavan, Wisconsin, USA
    You could start out with a set of extension tubes, kenko makes a decent set as well as the Nikon set. They will give a much higher magnification with your current lens.
    The 105mm VR Micro Nikkor is a great lens and I use it quite a bit. That being said if most of your work is done with a tripod (as most macro is) you might find a good deal on a 105mm AF Micro Nikkor.
