what makes macro lenses special?
Discussion in 'Photography Beginners' Forum' started by florenceinitaly, Jan 9, 2010.
  1. florenceinitaly
    florenceinitaly TPF Noob!
    Jan 7, 2010
    89
    Hi,
    For macro photography, I'm confused as to what distinguishes "macro" lenses from regular prime lenses. For example (I use the sony a500), there's a 50mm F2.8 macro lens, and then a 50mm F1.8 prime lens.
    What is it about the "macro" lens that would enable it to do things the 50mm F1.8 prime lens can't? Can you take "macro" pictures with the prime lens rather than the macro lens?
  2. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    That's it, pretty much.
    Macro lenses let you get close, real close. A postage stamp, for example, would fill the entire frame - and then some.
  3. Pugs
    Pugs TPF Noob!
    Jun 13, 2008
    1,155
    Milwaukee, WI
    A macro lens will allow much closer focusing distances so that you can get more magnification of a subject, or rather, less reduction of the subject.
  4. florenceinitaly
    Jan 7, 2010
    89
    And say if I tried to take the same picture with the 50mm F1.8 prime lens, it wouldn't be able to focus at such a close up distance?
  5. florenceinitaly
    Jan 7, 2010
    89
    ohh i see, so is there a "spec" on the camera to tell you how close you can focus on the subject?
  6. Pugs
    Pugs TPF Noob!
    Jun 13, 2008
    1,155
    Milwaukee, WI
    No.
  7. TJ K
    TJ K No longer a newbie, moving up!
    Sep 9, 2008
    2,093
    Sunny South Florida
    The Macro part.
  8. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Yes, and it will be expressed as a ratio. A macro lens will be 1:1.
    A "Normal" lens will be something like 1:3.
    The spec is on the lens though - not the camera.
    EDIT
    Also, don't confuse this with the aperture. Some lenses will say "1:2.8" (for example) on them - this only means that the maximum aperture of the lens is f/2.8.
  9. florenceinitaly
    Jan 7, 2010
    89
    lol
    How about choosing between different focal lengths of macro lenses (ie. 50mm, 100mm vs 200mm), i know a 200mm would let you shoot from further distance...but if i had a 200mm macro lens and walked right up to a flower petal, will it focus?
  10. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Yes.
    All that changes is how close you have to be to attain 1:1. Longer lens lets you be farther away (which is generally good).
    My 100mm Macro, for example, does 1:1 at about 6 inches from the front of the lens.
  11. florenceinitaly
    Jan 7, 2010
    89
    i see, that likely explains why the price difference increases a lot between a 50mm to 100mm to 200mm macro lens.
    Does someone mind defining to me what the 1:1 thing means for macro photography?
  12. milesy
    milesy TPF Noob!
    Jan 6, 2010
    99
    4
    Melbourne
    1:1 just means that you can focus on something (say a fly) and it will fill the entire size of the sensor where as 1:3 for example means that something willonly fill 1/3 of the sensor
