What Settings to Use on Nikon D80
Discussion in 'Photography Beginners' Forum' started by BoxPhotographer, Jun 23, 2009.
  1. BoxPhotographer
    BoxPhotographer TPF Noob!
    Jun 23, 2009
    101
    Ontario, Canada
    I am taking photo's for a graduation tomorrow, and it'll be a gym, dark, with only a few spot lights on stage. Afterward there will be a band playing.
    After all this is over there is a dance which I do not know about the lighting. All I know is that it'll most likely be dark.
    So what should I set everything to for the best photo's?
  2. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    I think you just kind of asked us how to be a good photographer and learn it all in the 8 hours before your graduation. That's a bit of a tall order, I'm afraid.
    I would suggest searching this forum for "event" and look for advice threads on shooting events as you'll probably find quit a bit of valuable info.
    Aside from that, it's all about knowing exposure and setting your camera's shutter, aperature and ISO properly to meet the needs. If you have an external flash with some kind of diffuser or softbox, that will help. Using the built-in flash is not recommended. In your case, I would set it to Program or Auto (ideally not auto, but you may have to if there isn't enough light and you don't understand ISO)
    Mind you, I'm making about a million assumptions here.
    Good luck.
  3. Sachphotography
    Sachphotography TPF Noob!
    Jun 17, 2009
    1,229
    Tulsa, OK
    First off. I pray that you have an external flash. If you dont... well go get one. Your not going to get anything decent without one.
    2. Id shoot at 800 ISO. It will show grain but it will be clean and fast.
    3. What Lens do you plan shoot with?
    The situation you are shooting in is not a fun one. Most likely you will need to do some good WB processing afterwards as well. Those gym lights are a pesky thing. So orange. I would recommend getting there ahead of time and shooting a ton to try and get something good. The best results are from practice. Without being there nobody can tell you exactly what to have set up. Good flash & good Glass will be your best bet.
    Daniel Sach
    Sachphotography Fine Art Photography The homepage of Daniel Sach and his photography Company
  4. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    Tall order indeed without much time.
    Above ISO800 the D80 sucks and I seldom go beyond ISO400 on mine unless it's absolutely necessary. Get / rent a flash (nothing less than a SB-600)......
    Oh crap, you don't even mention your lens(es).....
    Hope for the best, plan for the worst. Not enough information.....
  5. Sachphotography
    Jun 17, 2009
    1,229
    Tulsa, OK
best nikon d80 settings
best setting for nikon d80
best settings for nikon d80
nikon d70 settings for a graduation
nikon d80 best settings
nikon d80 recommended settings
nikon d80 settings
optimum settings for nikon d80
recommended settings for nikon d80
what is the best setting for id picture using nikon d80
