What should I choose
Discussion in 'Beyond the Basics' started by tkaat, Dec 10, 2008.
  1. tkaat
    tkaat TPF Noob!
    May 27, 2008
    307
    On a Island
    I have been thinking of buying a new lens for my D40. My problem is I can't decide if I should buy a nifty-fifty or a 55-200 or not get a lens at all and buy a Sb-600.
    The reason I can't decide is that I am a noob to photography - 6 months - and I keep on hearing that it is good to use a fixed lens as your beginning/ main lens because it limits you and forces you to try and obtain your desired photo a different way. And I was thinking about getting the 55-200 because I was at one of my little sister's ocean swim, during summer, and couldn't zoom in close enough to get a good photo but also I am like how much am I really going to use the 55-200.
    I am in to all types of photography but mostly into macro, landscape, & portraits.
    Or what do you think I should get
  2. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    personally based on the photography your into, i think i would get a flash, epecially for the macro stuff... but i sure do love my nifty 50... and i hardly ever use my 70-300...
  3. andrew99
    andrew99 TPF Noob!
    Jan 23, 2008
    672
    Toronto, Canada
    The Nifty Fifty is great, but it might be annoying to manual focus it on your D40. If you shoot indoors a lot, the SB600 will be a huge help. As for the 55-200, I'm not familiar with that lens.
    I think you need to decide what is the biggest limitation you have now as far as getting the shots you want, then you will know which one to buy! :)
  4. Overread
    May 1, 2008
    24,063
    4,171
    UK - England
    ways to choose a new lens/bit of kit
    1) work out how much you have to spend
    2) work out where your weaknesses in your current kit are - you speak of reach at the pool and not having enough - and also that macro is an interst, yet you lack a proper macro lens
    3) research the market to find out the cheapest and the best lenses for achiving your end goal (asking on forums can be a part of this phase)
    4) work out which bit of kit you want - do you go with what you can afford now or do you save and wait to get something of a higher level of quality
  5. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    BS in my humble opinion. You should learn to compose with perspective, as in all other 2D visual arts. A fixed focal length tends to encourage composition by field of view. Perspective is controlled by where the camera is in relation to the subject; a variable focal length allows for cropping in camera, which is usually a good idea for small formats.
    A good reason to get the nifty 50 is that it's cheap and fast. Fast often comes in handy.
    If you don't have a flash I think a good external flash will teach you more than a new lens. For all the talk about sharpness and resolution it's really almost all about the light.
