What size filter should I get?
Discussion in 'Photography Beginners' Forum' started by anubis404, Jun 3, 2008.
  1. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    I am shopping for a polarizing filter for my Nikon D40 with kit lens (18-55mm). How do I know what size filter to get? I am seeing 46mm filters, 28mm filter, 55mm filters, etc. Which should I get that would fit my lens?
  2. Rachelsne
    Rachelsne TPF Noob!
    Jan 24, 2008
    1,137
    Yorktown, VA, USA
    on your lens it will give you a size, if your still not sure, look inside your lens cap and there will be a number that will tell you the size also :)
  3. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    if you have several lenses with different filter thread diameters. get a filter for the largest and buy step down/up rings for the other lenses.
  4. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    52mm
  5. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Depending on how seriously you'll be taking this, 77 and a step up ring.
  6. TamiyaGuy
    TamiyaGuy No longer a newbie, moving up!
    Jun 25, 2007
    1,078
    Chelmsford, UK
    The correct size for the 18-55 kit lens is 52mm. However, at the very wide end of the lens, it might produce some vignetting, so you might want to think about a larger sized filter and a step-up ring. Of course, larger filters cost more, but most higher-end lenses have a 67-77mm filter thread.
    I would personally recommend a cheap-ish 52mm filter, and save up for a more expensive filter to go with your new lens (if that's what you want, mind).
  7. Alfred D.
    Alfred D. TPF Noob!
    May 17, 2008
    381
    Or a 'slimline' (low profile) filter.
polarizer filter 28mm lens what size
