Whats a Macro
Discussion in 'Photography Beginners' Forum' started by chrisburke, Jun 12, 2007.
  1. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    I just got a lens in the mail yesterday.. its a 52mm .045x digital wide lens with macro... what is a macro... the small piece on the bottom of it says its the macro, but what is it, what does it do?
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    A macro lens is often combined with a re-production factor, a number 1:something. Macro lenses can focus closer to the front element than other non-macro lenses. The true macro lenses with their fixed focal length often achieve reproduction ratios of 1:1 That is a 2cm wide object will project a 2cm wide image in the sensor, and thus when blown up on the computer screen, about 50cm wide depending on the sensor resolution or the type of film.
    Basically it should be called a micro lens since it allow you to take big pictures of small things like a drop of water: http://farm2.static.flickr.com/1193/533225920_cff12621a3_b.jpg (Taken with a 105mm 1:1 Macro lens)
  3. deanimator
    deanimator TPF Noob!
    Jun 1, 2007
    534
    East Germany
    Wikipedia has a nice article about the subject here http://en.wikipedia.org/wiki/Macro_photography
    And they make a good point about the ratios being produced for digital cameras, for example a ratio of 1:4 creates a life-size image on a 4 x 6 print
  4. chrisburke
    May 25, 2007
    2,107
    Thanks Guys, that helps a lot
